Question about Air Tools & Compressors
Compressor oil check
Have an older compressor with no obvious oil fill location. Runs till cylinder gets hot then stops-will add oil, dont know where to add it..... part # on cylinder is 4065237. melben products 1098607
  • 142 Answers
They don't always make them obvious. Look for a bolt in a place it shouldn't be, like on the end of the compressor, and look under it. Are you sure it is not an oiless compressor. A picture would help figure it out
Posted on Jul 18, 2009
We have a 2004 XAS 136 rotary screw compressor. The problem started suddenly. Engine starts and runs fine. On activating compressor, (blue button) there is a bit of exhaust smoke and engine seems overload....
First check oil level in both the engine AND the compressor if it has an oil sump.
It ounds like the piston rings or cylinders are scored causing the engine to have no power under load and to burn oil, and the compressor may also be seized.
if there is the correct amount of oil in the engine then consider an oil change and add some
Ametech Engine Restorer Oil Additive
www americantechnology co uk
to both engine oil and the compressor oil (providing it also uses ordinary engine oil too)
Oct 10, 2013 | Air Tools & Compressors
What causing hot air to come out of air compressor cylinder
The air is always warmer coming out of a compressor. As air is compressed it builds heat, also the mechanics (friction) of the compressor builds heat. So you add these two together and you get some rather warm air out of a compressor, especially if it runs for a while. I hope this helps.
Apr 23, 2012 | Air Tools & Compressors
I have a craftsman air compressor, model 919.167620, that will start running and then after about a minute it starts running slower and slower till it stops. it doesn't seem like it runs long enough...
The nonreturn valve that lets the air into the tank is stuck or faulty and not letting the air through, so pressure is building up in the pipe and cylinder and stopping the motor. If you open the back of the valve and run the motor you will know if that is the problem. Stephen.
Sep 24, 2011 | Garden
Dewalt D55168 air compressor runs until 95 psi and never stops. Pressure never goes above 95 psi. It use to stop around 140 psi.
Check for leaks all over the machine. Possibly the O ring on the drain valve is damaged. If the machine is oil-less, the big rubber O ring on the piston could be worn away.
When the machine is turned off can you hear air leaking from anywhere?
Mar 31, 2011 | Dewalt D55168 1.8 HP Wheeled Portable...
I have a150 psi compresor that is 5 years old. it currently does not reach 150 psi without running for a very long time and sometimes just stays at 120 psi and wont get any higher ( the motor just keeps...
Repair all leaks to get true test of condition of cylinder / piston ring and check/reed valves. It is reccommended to know amount of time to fill tank when new and compare this time to present. Filling time is indication of wear. Another method to discover wear is to remove cover to pump and examine condition of cylinder wall close to top of cylinder (on oil-less models). If you see scratches on cylinder, air is leaking past piston seal. On pumps that use oil, very hot discharge air hose or pump head is indication of leaking valves or head gasket. Sears usually has good prices on replacement parts. Good holidays
Dec 08, 2010 | Craftsman Air Tools & Compressors
I just bought a used Craftsman air compressor at a garage sale...100PSI, twin cylinder, 1HP motor. Model # 106.154440. Runs fine, but wondered how to check the oil level in the compressor case and if it...
I have a Sears 106.154581 most likely like yours. You will find a small plug (fill hole) and slightly larger plug on side of pump close to bottom (drain hole). Fill compressor with compressor oil to top thread of fill hole. Oil should look rather clear with very little odor. Compressor oil is available at Lowes for about $3. Good luck
Aug 16, 2010 | Craftsman Air Tools & Compressors
It runs but doesn't build pressure.The tanks are closed.
piston rings gone maybe or a blown gasket strip the cylinder off and inspect and get back to me buddy
Sep 26, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Need to know how to check trans fluid in a 1998 old cutlas. Found add hole but no specs. Cant see fluid, but dont want to over fill ?
there is a special tool for checking the fluid, in order to get a proper level check the trans fluid must be very hot, at least 180 F, to check it without the guage tool stick your finger in the hole, you should just be able to touch the fluid when your 1st knuckle is at the lip of the fill hole.
Sep 01, 2009 | 1998 Oldsmobile Cutlass
Air Compressor will not build up over 25 PSI
your max pressure switch is faulty, and shutting off the power early. replace switch, check owners manual for location(should be near power wires)
Jun 14, 2009 | Hitachi Air Tools & Compressors
Air Compressor won't go over 35PSI
Hello, Your air compressor is leaking in the cylinder and is unable to produce more than the 35psi. Unfortunately oilless air compressors do not last very long. The rings and cylinders wear out. I have successfully repaired some units but, I usually recommend buying the oil type compressor. They last forever. If you want to try and repair it let me know and I'll help you. Good luck.
Jan 22, 2009 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
122 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
