Question about Meade CaptureView 8x42 Binocular
Replacements Parts I need to find a replacement for the battery compartment cover.
  • aloni1 Mar 06, 2008
    me to.
    please help.
  • smileplease Sep 01, 2008
    me 3, currently use some strong rubber bands to hold the broke lid in place, but really would like to find a replacement door.
Does any one still know where to find a battery compartment cover for the capture view
Posted on Aug 04, 2008
I need battery pack and battery compartment cover
Go to the companies website. Many companies like Fisher Price offer replacement parts quite reasonably. Just put in the model number or name in the search bar on the companies site. If the parts are discontinued, the best place to look for replacements is ebay or craigslist. Best Wishes!
Jul 19, 2013 | Baby Gear
Where has the replacement battery CR1620 must be placed?
1) Open the main battery compartment
2) Remove the battery tray
3) Inside the battery compartment directly behind the LCD screen there is a small cover about the same size as the CR1620.
4) Remove the cover
5) Replace the battery
6) Replace the cover
7) Replace the battery tray
Jul 20, 2012 | Polaroid Battery Grip for Canon EOS-7D...
Spare battery covers - to hold battrries in place
They sell replacements. Just scroll down the page and look for the "Replacement Parts" box on the right hand side.
Dec 18, 2011 | Vtech Kidizoom Digital Camera
Where is the coms battery for compaq evo n610c located
If your in the need to replace your cmos backup battery on your Compaq Evo N610c, N610v, N620c Series Notebook help might be just around the corner and thru the usage of this guide familiarize you with what you will need to solve the error prompts flashing on the screen regarding corrupt cmos. At this point you have come to realize that the notebook is no longer booting your Operating System should that be Microsoft or Linux OS's.
The first thing you will need to be familiar with, is where the cmos backup battery is located on your notebook. You can start by turning over the notebook to the bottom side and adjacent to the Main Battery will be a small rectangular compartment held down by two screws (Mini PCI Compartment Cover).
db96_2.jpg These two Phillips head screws must be removed in order to expose the cmos battery that's held in place by a battery holder.
db99_2.jpgThe battery holder accomidates the BR1225 Lithium 3 volt battery, allowing the two potentials of the battery to maintain power to the cmos chip and therefore sustaining the clock/date settings as well as the boot sequence set by the end user. These non rechargeable lithium batteries provide operational function while the notebook is powered off.
After having identified the location of the cmos battery, and having removed the two screws that hold the black rectangular plastic cover, use a non magnetic/plastic tweezer or equivalent probe and pry out the BR1225 battery retained in the Battery Holder. If you don't have access to a Volt meter to determine the diagnosis of the battery, then assume that it requires replacement, where a replacement would be any brand of battery that suits the BR1225 specs: 3 volts approx 40maH 12mm diameter 2.5mm thickness no wires and no connector. HP refers to call the cmos battery by the name of RTC Disk Cell. To order from HP refer to HP Spare Parts Number 241439-001 (Miscellaneous Plastics Kit Component) Applicable to Compaq Evo Motherboards: 291581-001 (Evo N610c) and 319778-001 (Evo N620c)
d0e4_2.jpgNow, while replacements can be for just any electronic store near your home/business, pharmacies also carry these types of batteries, but if your choice is to buy them here on ebay, we recommend buying them from a seller who has other Evo Part integration and has proven themselves to be fully knowledgeable on HP/Compaq Evo Models, whereby most likely they will stock other parts you will need for your Evo such as Hard drives, LCD inverters, LCD display, optical drives, memory and maintenance care products. Below are two sellers and the ebay store links to their Cmos Disk Cells. We have no affliation with them, but as buyers we have purchased from both of them in the past with good success and can recommend them.
good luck
Aug 02, 2011 | HP Compaq Evo n610c Notebook
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
Unable to pop battery compartnent in Health o meter EVERweigh
The whole top cover which is the part that you stand on (loading platform) comes off. Turn the scales upside down, pull the sides of the plastic cover to unclip the catches and the body can be removed from the cover. Remove the screws to the displlay and there will be a battery compartment underneath the display. Remove the cover to the battery compartment and make note of the battery orientation. Replace the battery in the correct orientation or you will destroy the scales. Repace the battery cover. Scew the display to the body. Press the cover on the body with the display showing through the window.
Jun 05, 2009 | Sunbeam Health O Meter Body Monitoring...
Replacement remote for window unit air conditioner
I have that model Air conditioner with remote. Although the remote is marked Admiral thats the only identifying marks on the outside. Here are pictures of the remote.
Top View
Side View
Battery Compartment Cover
Here is what is printed on the battery compartment cover label.
Drawing No: DF11F1-01 (AL) KYK-1801
Part No: 814011422
QA: 01
Date: 2005.01.11
Hope this helps. You might try a company called Vance Baldwin they usually carry a large inventory of remote replacements for all kinds of applicances. Had to get a remote for my Panasonic DVD player and it was only $12.00 (brand new)
Mar 15, 2009 | Whirlpool ACC108PS Air Conditioner
Maintain all-weather capability of my camera
The camera loses its weatherproof capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Make sure that all the covers are closed before using the camera. •Wipe any water off the camera before changing the battery or card. •If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Salt water spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. •Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. •If the rubber packing becomes worn or damaged, contact your nearest Olympus service center. (A charge is made for replacement of parts.) •If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover, otherwise water may get inside the camera. •The rechargeable battery and other camera accessories are not weatherproof. Care should be taken when using the accessories.
Sep 01, 2005 | Olympus Camedia Stylus 300 Digital Camera
Meade CaptureView 8x42 Binocular Logo
181 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
