Question about HP Photosmart C6180 All-In-One InkJet Printer
Yellow ink cartridge is perfectly installed and new but printer is displaying messgae to replace the cartridge
  • 26 Answers
Solution:
* Remove all the ink cartridges
* Perform the reset given below
==== NVM RAM Reset ====
Press and hold OK and Help while plugging in the power cord
Continue holding the buttons down until the product control panel turns blank, then release the buttons.
Use the On button to turn on the product. The reset information appears on the control panel display.
* Once you have performed the steps re-insert the ink cartridges and check if you are still getting the error message
Posted on Jul 18, 2009
I refilled my black cartridge of Pixma iP 1600. I have done it 3 times before and it worked perfectly until yesterday. Now when I refilled it the 4th time, the yellow LED blinks 5 times and then the green...
The manual for the PIXMA iP1600 says the following concerning the 5 blinks:
The ink cartridges are not properly installed, or a non-supported ink cartridge is installed (the ink cartridge EEPROM data is abnormal). Install the ink cartridges properly. Or, confirm that the supported ink cartridges are installed.
If you haven't already I would take a look at the electrical contacts on the cartridge to make sure they are clean (free of dust and ink) and then reinstall them in the printer. If the printer gives the same error, it's time to buy a new cartridge. 3 refills from a cartridge is not bad at all.
Hope this helps,
Steve
Feb 10, 2011 | Canon PIXMA iP1600 Printer
Printers do not recognize yellow cartridges
http://www.fixya.com/support/r3845491-ink_cartridge
Check out there FIRST befoe you get into things too deeply
A lot of common tips that tend to help a lot of people.
Bob
Jul 22, 2010 | Epson Stylus Pro 9600 InkJet Printer
Ink system failure error telling me to refer to printer documentation error 0xc18a006
The "Ink system failure" error is caused by air in the ink feed tubes, this happens if you use poorly filled cartridges or allow you cartridge to run all the way out. We have a step by step guide to purge the ink feed tubes posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ This should get your printer back going in about 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 02, 2010 | HP Photosmart C6100 All-In-One Printer
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
The black ink cannot be
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed? Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred? Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If not, do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then there are other things we can try - assuming other solutions haven't worked either. Report back on my queries etc.
Feb 10, 2009 | Epson Stylus C43SX InkJet Printer
I HAVE NO INSTRUCTIONS FOR OPENING THE CARTRIDGE COVER ON MY EPSON rx595 PRINTER AND CHANGING THE CARTRIDGES.
Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones.
Follow the steps below to replace one or more ink cartridges that are expended:
  1. Turn on the printer.
  2. If a cartridge is low or expended, you see a message on the display screen. Note which cartridges need to be replaced and press OK.
  3. Open the scanner, then open the cartridge cover.
  4. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
  5. Remove the cartridge from the package, but be careful not to touch the green chip on the edge.
  6. Remove the yellow tape from the bottom of the ink cartridge.
    Caution: Do not remove any other labels or seals, or ink will leak.
  7. Insert the new ink cartridge into the holder and push it down until it clicks into place.
  8. Once you replace all the cartridges that need replacing, close the cartridge cover and push it down until it clicks into place.
  9. Close the scanner.
  10. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the display screen, ink charging is finished.
Caution: To conserve ink, never turn off the printer while ink is charging. If you see an ink replacement message on the display screen, press OK and press down all the cartridges securely
Jan 08, 2009 | Epson RX595 Photo All-In-One Printer
Brother DCP-115C Printer: "No Ink" message continues even after old ink cartridge (still some ink!) is replaced with a new one.
Reset the printer to factory settings
Turn off the printer. and turn it on again.
If still not working
Take out the cartridges, turn off the printer
Turn on the printer and put the cartridge again.
Oct 27, 2008 | Office Equipment & Supplies
Display says I am out of yellow,
Hi, since you've already replace the yellow ink cartridge for several times and its not recognize. Your printer might have a defective printhead. You may take your printer to the nearest HP service center in your area so that they can look on your printer further.
---->> Tirzo
Jun 04, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
223 people viewed this question
Seeker5211
Seeker5211
