Question about Banner Faucets Double Handle Kitchen Faucet...
I have a Castille collection Banner kitchen faucet. Recently I had a leak that wouldn't quit from the hot water side. I discovered that there is was a broken plastic piece that fits onto the stem and into the handle. When I reassembled it with the new plastic piece, I can't turn the water off. I think it has something to do with the bottom of the stem which has 2 holes and their relationship to the hole though which the water enters the faucet. Can you advise?
  • 297 Answers
You may have the stem in backwards,flip in around and see if this works,sometimes they only go in one way to work right.
Posted on Jul 22, 2009
Testimonial: "I had the plastic piece in wrong. Thanks."
How to adjust Banner M580 Series faucet to provide a better hot/cold balance?
Could be a defective mixing valve or blockage in the cold water input line to the valve
Jul 26, 2016 | Banner Faucets Pro Series M580 Single...
How do I take it apart
faucet should have allen screw hole behind or under, just look around and you will find it. they unscrew with allen wrench
May 07, 2012 | Banner Faucets Castille 600 Series Brushed...
Faucet leaks when water is turned on at the spout base. I took the set screw out of the back but can,t remove it to access the orings or seals
better turn off the main line first, screw the ring again putting some extra pressure because usually rings are tighten so hard.you have to replace the base of the faucet.
Jun 22, 2011 | Banner Faucets Castille 700 Vintage Series...
I have a banner kitchen faucet and the water flow recently decreased to now is a dribble. when the center cartridge is taken out the water pressure is great but when put back in the water comes out of the...
Clean and or replace the cartridge. Cleaning the cartridge means taking it apart and it is much easier to just replace it but it's worth a try if you are so inclined.
Mar 03, 2011 | Banner Plumbing
Hot water side slower pressure than cold side on one handle kitchen faucet
If problem is isolated to one faucet, then clog is located near that faucet.
I have same problem on one faucet when sediment and dirt collects at shut-off valve for some reason.
Problem can be at shut off or at supply tube or at faucet ... or all 3.
Repairs get things kind of wet so get out bucket and towels.
Take apart center mixing valve on faucet and turn water on to see if problem flushes out.
Disconnect hot side supply tube at faucet. Turn water on and see if that flushes problem out.
Remove shut off valve and turn water on to see if that flushes problem.
Replace shut-off valve.
Next place to look is elbow inside wall.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 19, 2011 | Delta 2402 Classic Single Handle Kitchen...
WHEN MY SHOWER IS TURNED ON THE WATER ALSO FLOWS OUT OF THE FAUCET. HOW DO I TAKE OUT THE STEM TO CHANGE THE SEALS?
The seal is not a 100% seal, but to access there are two types, one type the tub faucet screws on and the other style is retained by an allen set screw. if you have the set screw type, you will notice a slot on the underside of the faucet, at the tub wall end, look up in there. If you see an allen, loosen it and pull the faucet straight off. if no slot or allen, unscrew the entire faucet, counter clockwise (top to the left, for those digital clock people...).
Nov 15, 2010 | Banner Faucets Castille 600 Series Brushed...
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Drips when off on hot water side, not sure if this faucet has replacement cartridge.
YES, HOME DEPOT... THE EMPLOYEES MIGHT NOT HELP YOU BUT THERE IS A FAUCET CARTRIDGE GUIDE THAT WILL HELP YOU FIND YOUR EXACT ONE, AND IF THEY DON'T HAVE IT IN STOCK IT WILL ONLY TAKE A COUPLE DAYS TO GET IN. TRUST ME I USE TO BE A PLUMBING EXPERT AT HOME DEPOT.
Oct 16, 2009 | Banner Faucets Castille 600 Series Brushed...
Leaking how do I replace cartriges
well feel the water is it cold or hot then there should be Phillips screw on top the handle you have to pop off decorative cap or some of them unscrew then there be a larger nut unscrew that make sure the water off or you will get wet! that the baby you replace.
Jul 07, 2009 | Banner Faucets Castille 600 Series Brushed...
Banner Faucets  Double Handle Kitchen Faucet... Logo
130 people viewed this question
Top Banner Plumbing Experts
Mike
Tom Chichester
Andrew Bugbee
Are you a Banner Plumbing Expert? Answer questions, earn points and help others
