SOURCE: Paper Jam
The fuser unit has a pape sensor. If, for some reason, the sensor is stuck, the printer will read a paper jam. Open the rear door and inspect the paper sensor located in the fuser assembly. See if it came out of it's original position or if there is something blocking it from moving freely. Good luck.
SOURCE: Screenwriter 3 Fuser Problem
go here to the 3N section, email these guys and see if they can help you.
hope this helps
thanks for your rating
SOURCE: jams when duplexing
There is a set of clutches in on the upper back side of the right side door.
The inverter clutch tends to go bad on that cluster.
But if you are replacing one may as well do both. They are electromechinical clutches.
SOURCE: Photocopier says close duplexer cover
in the back of the duplexer their is an socket. It have large of wiers see that there is no brack in the wires or it close properly
SOURCE: how to remove covers and fuser unit?
Ive got the same problem :( and because i used compatible cartridges, it apparantly voides the warrantly, so staples will not fix it :( so im now stuck with a £260 uselss printer :( good luck getting it fixed.
