Have a carrier dual gas thermal pump everything works fine diconnected thermostat to srew back plate into wall thermostat seem to work but can'T get ANYTHING going, funance , heat, or pump.
  • 614 Answers
Blown fuse in Air Handler. It should be on the fan board inside the unit. 5 amp auto fuse replaces it and it will be ok. Russ. Happens all the time dont worry about it
Posted on Jul 18, 2009
Williams wall furnace
Thermostats aren't very expensive. You can get universal ones at home improvement stores.
Dec 06, 2016 | Williams Heating & Cooling
Carrier high efficiency furnace blower not turning when thermostat set to on position
is breaker and emergency shut off on-- check ---thermostat /operating correctly--gas /valve on--thermocouple /in working order--gas valve /operating correctly---reset ,high limiter,safety 's //are correct and not popped ---fan working order ---
Oct 25, 2016 | Carrier Heating & Cooling
Will not get hot
If it's a gas dryer, check the thermal fuse, gas valve solenoid, igniter, element, flame sensor, high limit thermostat, or cycling thermostat.
If electric - check the heating element, thermal fuse, or thermostat.
Overall, dryers, specifically electric dryers, are very easy to work on - youtube has some great videos too.
Feb 19, 2014 | Samsung Dryers
I have a dle2532w and everything seems to be working fine but there is no heat, I have checked my breakers and everything is fine. I took it apart and checked the element and the thermostat and the thermal...
You need to replace the operating thermostat along with the thermal fuse. This thermostat controls temperature in the drum and if it fails, it will just put out heat constantly without regard to temperature. Be sure to check the exhaust vent in the house walls to make sure they're cleaned. Good luck
Jun 20, 2011 | LG DLE2532W Electric Dryer
The plate warmer will not work tonight. Everything else seems OK. I've tried turning the appliance off at the mains and then back on again, but it didn't work
Hi
I have just had the same problem, the connections just fall off the heater! Waiting for a response from Rangemaster....
cloudbase50
Dec 02, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
We have a Carrier Heat pump. Today the heat pump and (gas) furnace turned off completely and the thermostat is blank. We've checked the fuses and they seem to be fine and everything else is working...
Is the thermostat battery powered or powered by the transformer. If it is powered by the transformer then the transformer may have gone out. Turn the thermostat to off. Use a multimeter to check for 24 vac between R and G on the thermostat. If you don't have it there, locate the transformer in the air handler and check for it at the transformer secondary. If you don't have it there check for 120 vac at the transformer primary. If you have voltage on the primary but not the secondary then the transformer is bad and needs to be replaced. Let me know what you find and I can offer more advice.
Aug 15, 2010 | Heating & Cooling
Roper Gas Dryer
The first thing I would check is the thermal fuse (#6 on the bulkhead parts break down diagram). Replace if it's open.
Also, the manufacturer recommended to replace the cycling thermostat (#8 on the bulkhead parts break down diagram) too if the thermal fuse is open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model RGX4634KQ2
"Did it solve your problem?"
Jan 28, 2009 | Roper RGX4634KQ Gas Dryer
I have a viking rangetop and the griddle's gas is not turning on the glow plug works fine but no gas seems to be coming out.
Check the amperage draw to the igniter, if it is over 3amps and no gas, first off check the valve on the manifold behind then control panel if the valve is open then check the wiring to the thermal valve if it is connected then it would appear that the thermal valve is defective.
Sep 06, 2008 | Viking 48" 6 Burner, Grill Professional...
Kenmore Elite Electric Convection Oven Not Working
Check the voltage at the wall Sounds like you have lost one 120 voltage side Red to white should read 110-120 black to white should read 110-120 red to black should red 220-240 check at range and at the wall hope this helps
Aug 25, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
