SOURCE: Motorola FV500 2 way radio can send/cant receive
I'm with Neto on this one. It coul be just a problem with "tones". I'm not familiar with that exact model but check for a "monitor" button. If you have one on the radio... press it down.... this should open up the squelch completely. You should hear static.... thats what you want... basically you will hear everything that transmitted on that channel (frequency) regardless of privacy codes (tones). You can also do the same thing by turning the squelch all the way down to 0 ( as Neto was suggesting). The monitor button is more convient but if you don't have that function do as Neto said and turn the squelch down all the way. Once the squech is turned down or monitor button is engaged you should be able to hear everything transmitted on that channel including static (rushing sound). With the squelch turned down or monitor button pushed, try transmitting on the problem radio... if you can hear the problem radio easily with monitor button pushed or squelch turned down then the privacy codes (tones) are set differently on each radio. You want the privacy codes to be the same on both radios otherwise you won't hear any rx audio or the transmitted audio.
SOURCE: RPL & TPL tones used in T-5720
The T5720 user manual does not list the TPL codes possible in the radio. However, they are the standard list, with zero being "open squelch" (no code). Here is a link to a Motorola manual which has a list of the PL codes in order on page 43. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
On the T5720, another item to what for is the Qt noise filter. Be certain to set it to zero unless using the T5720 with others of the same model. It can also block transmissions. Here is a link to a user manual for the T5720 http://lib.store.yahoo.net/lib/starbattery/T56XXusersguide.pdf
SOURCE: motorola gp 63
The GP-63 and the GP-68 uses the same users manual. You can download the user manual which also has programming and cloning information in it from:
http://www.batlabs.com/2way.html and choose GP-63......Good luck
SOURCE: motorola gp 68
Batlabs at http://www.batlabs.com/2way.html (Hand Held Radios) has the GP-68 users guide(Operation Guide), on the right side I think what you might be asking is in "Basic Operation 2", if not look into the Programming section below it.
SOURCE: GP 360 Radio Charger
On a Motorola charger, when the battery is charging the light should be a constant red (or amber depending on the charger). When the charge cycle is complete the light will change to solid green. Sometimes the solid green time is brief, as the battery will begin to lose charge, and the charger will go back into trickle mode and change once again to red (or amber). In most cases, a flashing light indicates a problem, such as a bad or shorted battery, an incorrectly seated battery, dirty battery contacts, or a bad connection with the battery. (Note: Batteries last 18-24 months typically. Check your date code for the age of the battery.)
There were several chargers made for the GP360, including but not limited to a 60-minute charger, a 90-minute charger, a 10-hour trickle charger and a 6-unit gang charger which would be a rapid rate, either 60- or 90- minute. If you would supply your charger's model number we could tell you which one you have.
