Cars & Trucks Logo
Richard Clipp Posted on Jul 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows and mirrors inop, fuses OK, no fault codes
Window and mirrors fuses are good. Scan tool not detecting power window control module. Also not detecting mirror control module. Signals from switches are recognizeable like requires wiring harness or control module.
Jeff Armer
Level 3:
  • Cars & Trucks Master 15,575 Answers
  • Posted on Jul 23, 2016
Jeff Armer
Level 3:
Answers
15575
Questions
Helped
7104397
Points
73899
Depending on the make , model an year vehicle You won't be able to communicate with door module an not all vehicles have door modules ,what makes you think yours has door modules An it depends on scan tool , has to be factory or professional grade scan tool . Your probably have broken wires inside the rubber boot from the body to the door . An power windows usually have a circuit breaker not a fuse .
  • Jeff Armer Jul 23, 2016
    Suggest you consult a wiring diagram to see what all is involved in those circuits. An there wouldn't be a separate module for power mirrors , control would come from Driver door module
    Go tohttp://bbbind.com/free_tsb.html free wiring diagrams .
I have a 2002 Pontiac Booneville SE. The interior lamps, door locks, windows and sun roof do not work but I still have power to the mirros on the doors. What could be the problem?
Mirrors are separate from the other things.
Driver and Passenger Outside Mirror Operation
In order to control outside rear view mirror adjustments, two switches are contained within the driver door switch assembly (DDSA). The DDSA contains a built in mirror select switch and a built in mirror position switch. The DDSA reports the switch activity to the driver door module (DDM).
The mirror select switch is used to select which mirror, left or right, is to be moved.
The mirror position switch is used to move the mirror that has been selected to the desired position. When the mirror position switch is activated in a Up, Down, Left, or Right direction, the DDSA recognizes the input and sends this data on to the DDM via the power door serial data circuit. Depending on which mirror has been selected for adjustment, the DDM either moves the driver door mirror to the requested position, or sends a power door serial data message to the passenger door module (PDM) indicating that the passenger door mirror needs to be moved. The PDM then moves the passenger door mirror to the requested position.
Each mirror has two reversible motors for position adjustment. The door modules control the reversible motors by supplying Battery Positive Voltage (B+) and ground to these motors.
Outside Mirror System Components
The power outside mirror system consists of the following components:
• Driver door switch assembly (DDSA)
• Driver door module (DDM)
• Passenger door module (PDM)
• Driver outside mirror
• Passenger outside mirror
• Power door serial data circuit
• DRV MDL 10 A fuse (door module logic and internal driver operation)
• PASS MDL 10 A fuse (door module logic and internal driver operation)
Power Windows Operation
The vehicle is equipped with power windows controlled by the door modules. Each passenger door power window can be operated, either from a switch built into the driver door switch assembly (DDSA), or from a switch mounted locally on its associated door. The driver door power window can only be operated from the driver door window switch built into the driver door switch assembly (DDSA).
When the driver door module (DDM) receives a window switch request from the DDSA, the DDM checks the Class 2 serial data to see if the status information is correct (i.e. ignition switch position) to permit window operation to occur. If the status information is correct, the DDM, either supplies power and ground to its associated window motor, or, if the request is for one of the passenger windows, sends a command via the power door serial data circuit to the passenger door module (PDM, LRDM, or RRDM) controlling the window. The passenger door module (PDM, LRDM, or RRDM) controlling the window then supplies power and ground to its associated window motor to move the window as requested.
When one of the local window switches mounted on one of the passenger doors is operated, the associated door module examines the request and checks to see if there are any messages from the DDM prohibiting the movement. If conditions are correct, and no prohibitive messages have been received from the DDM, the associated door module then supplies power and ground to its associated window motor to move the window as requested.
The thing to do first would be to hook up a factory or some other type professional scan tool an check for DTC'S - diagnostic trouble codes.
DTC B3377, B3382, B3387, B3392, B3397, B3452, B3457, B3462, B3467, B3472, B3477, B3482, B3517, or B3522
Circuit Description
The switch that failed and generated this diagnostic trouble code (DTC) is part of the driver door switch assembly (DDSA). The DDSA contains a microprocessor which takes the signal generated by this switch and assigns a digital message to it. The DDSA then sends this message over a power door serial data circuit to the driver door module (DDM).
Same thing for locks.
The DDM must be powered and must not have DTCs B1327-Battery Low Voltage or B1328-Battery High Voltage set for this DTC to set.
Your best bet might be to find a good auto electrician.
2answers
2004 Chevy Tahoe Electrical Issues
Look at the end of the dash and between the drivers side door for a second fuse panel. I think everything you mention works on one data bus. You can remove the button pad on the drivers door. Since it gets used all th3 time i# might have gone bad messing up the works.
2answers
2005 Excursion....Just my power windows dont work. Power mirrors work for example. replaced swith module. Did not fix problem. Help!
  • All power windows are inoperative
  • Fuse(s).
  • Circuitry.
  • LF window control switch.
  • Accessory delay relay.
  • Go To Pinpoint Test B
2answers
1998 licoln continental driver side back passenger windows not working
I could see one window not working from a broken wire inside the door flex , but not both back windows . Back windows are controlled by LF door module . Both back windows have different grounds - LR G200 an RR G201 . Also both rear window switches have different power supply's .RR switch fuse # 18 30 amp . LR is fuse b# 9 40 amp . Both window motors or switche's going out at same time ???? wouldn't think so .
  • Driver door module circuits open/shorted.
  • Loose, corroded connectors.
  • Damaged window regulator control switch.
  • Damaged window regulator electric drive.
  • Open fuse in fuse junction panel Fuse 39 (10A), 28 (10A), 30 (10A).
  • Open fuse in power distribution box Fuse 9 (40A), 10 (40A), 8 (40A).
  • Glass, Frames and Mechanisms
    Inspection and Verification
    1. Verify the customer's concern by operating the power windows/heated back window to duplicate the condition.
    1. Inspect to determine if one of the following mechanical or electrical concerns apply:
      VISUAL INSPECTION CHART Mechanical Electrical
      • Front door power window regulator damaged.
      • Front window run damaged.
      • Front door window glass out of window run.
      • Front door window glass broken.
      • Scratched grid.
    1. If inspection reveals an obvious concern that is readily serviced, correct the concern before continuing with Inspection and Verification.
    1. If the concern remains after inspection, connect the Rotunda New Generation Star (NGS) Tester 007-00500 or equivalent to the data link connector (DLC) located beneath the instrument panel to perform DATA LINK DIAGNOSTICS test. If the NGS responds with NO RESPONSE/NOT EQUIPPED for the driver door module, go to Pinpoint Test A . If the NGS responds with NO RESPONSE/NOT EQUIPPED for the lighting control module, go to Pinpoint Test B . If the DATA LINK DIAGNOSTICS test is passed for the drivers door module and lighting control module, retrieve continuous DTCs and execute Self Test Diagnostics for the driver door module and lighting control module to retrieve current DTCs.
    1. If self test is passed and no DTCs are retrieved, go to the Symptom Chart to continue diagnostics.
    1. If DTCs are retrieved, go to the Driver Door Module (DDM) Diagnostic Trouble Code (DTC) Index or Lighting Control Module (LCM) Diagnostic Trouble Code (DTC) Index to continue diagnostics.
    1. If the driver door module cannot be accessed by the NGS, GO to Pinpoint Test A . If the lighting control module cannot be accessed by the NGS, go to Pinpoint Test B .
    Rotunda Service Bay Diagnostic System (SBDS®) 001-00001 may also be used to diagnose this system.
    • Power Windows Completely Inoperative
    • Supply open or shorted.
    • Ground open.
    • Window regulator control switch inoperative.
    • Circuits open or shorted.
    • Window regulator electric drive inoperative.
    • Driver door module.
    • PERFORM driver door module self test. Service DTCs. If no DTCs are retrieved, GO to Pinpoint Test C .
    • Single Power Window Inoperative
    • Window regulator electric drive circuits.
    • Window regulator electric drive.
    • Window regulator control switch circuits.
    • Window regulator control switch.
    • GO to Pinpoint Test D .
3answers
05 Explorer all of the windows stopped working at the same time and the radio also I checked all of the fuses and all of them are good Thanks in Advance if you are able to help me with this problem.
Bad relay more then likely .
Power Window Operation
The power window system operates under the control of the accessory delay relay. The instrument cluster module (ICM) grounds the relay coil to provide power to the power window system & the radio .
Symptom Chart Condition Possible Sources Action
  • Fuse(s).
  • Circuitry.
  • Instrument cluster module (ICM).
  • Driver window control switch.
  • Go To Pinpoint Test A .
The first step to diagnose this problem would be to hook up a factory scan tool an check for DTC'S - diagnostic trouble code's in the ICM . If no codes do pin point test A
Pinpoint Test A: All Power Windows Are Inoperative
Normal Operation Under normal operation the instrument cluster module grounds the accessory delay relay through circuit 1004 (LB/RD). Power is sent to the driver window control switch through circuit 400 (LB/BK) from the accessory delay relay. The driver window control switch is grounded through circuit 1205 (BK).
    Possible Causes
  • Fuse(s)
  • Open in circuits 400 (LB/BK), 1205 (BK) or 1004 (LB/RD)
  • Damaged accessory delay relay
  • Damaged CJB
  • Inoperative ICM
  • Inoperative driver window control switch
  • INPOINT TEST A: ALL POWER WINDOWS ARE INOPERATIVE Test Step Result / Action to Take A1 CHECK THE VOLTAGE TO THE DRIVER WINDOW CONTROL SWITCH - CIRCUIT 400 (LB/BK)
    • Disconnect: Driver Window Control Switch C504a.
    • Key in ON position.
    • Measure the voltage between driver window control switch C504a-6, circuit 400 (LB/BK) harness side and ground.
    • Is the voltage greater than 10 volts?
    Yes
    GO to A2 .
    No
    GO to A3 . A2 CHECK THE GROUND TO THE DRIVER WINDOW CONTROL SWITCH - CIRCUIT 1205 (BK)
    • Key in OFF position.
    • Measure the resistance between driver window control switch C504a-2, circuit 1205 (BK) harness side and ground.
    • Is the resistance less than 5 ohms?
    Yes
    INSTALL a new driver window control switch. REFER to Window Control Switch in this section. TEST system for normal operation.
    No
    REPAIR the circuit. TEST the system for normal operation. A3 CHECK THE ACCESSORY DELAY RELAY
    • Disconnect: Accessory Delay Relay.
    • Carry out the accessory delay relay component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
    • Is the accessory delay relay OK?
    Yes
    GO to A4 .
    No
    INSTALL a new accessory delay relay. TEST the system for normal operation. A4 CHECK THE POWER TO THE ACCESSORY DELAY RELAY
    • Measure the voltage between ground and accessory delay relay socket pin 85 and pin 30 harness side.
    Yes
    GO to A5 .
    No
    REPAIR the power supply circuit or central junction box (CJB). TEST the system for normal operation. A5 CHECK CIRCUIT 400 (LB/BK) FOR AN OPEN
    • Measure the resistance between driver window control switch C504a-6, circuit 400 (LB/BK) and accessory delay relay socket pin 87, circuit 400 (LB/BK) harness side.
    Yes
    GO to A6 .
    No
    REPAIR the circuit. TEST the system for normal operation. A6 CHECK CIRCUIT 1004 (LB/RD) FOR AN OPEN
    • Disconnect: Instrument Cluster Module (ICM) C220a.
    • Measure the resistance between accessory delay relay socket pin 85, and ICM C220a-5, circuit 1004 (LB/RD).
    Yes
    INSTALL a new ICM. REFER to Section 413-01 . TEST the system for normal operation.
    No
  • If you don't understand any of this , your best bet mite be to have a qualified repair shop look at it .
2005 trail blazer-power windows won't work and a/c only blows from the bottom
All the power windows are inoperative ?
Power Window System Components
The power window system consists of the following components:
Body control module (BCM)
LR power window switch
RR power window switch
Window up and window down relays in each of the rear passenger window switches
Window lockout switch
Reversible power window motors in each of the doors (circuit breaker protected)
LT DOOR CB 25A (System power for left rear window)
RT DOOR CB 25A (System power for right rear window)
Are you aware of the electronics involved ? control modules - computers ? Are you good diagnosing electrical problems . Do you own a professional scan tool ?
  1. Install a scan tool.
  2. Monitor the Driver Window Status Data parameter in the driver door inputs list.
Does the Driver Window Status Data parameter display an active state?
Your best bet would be to take your vehicle to a qualified repair shop . For both problems .
The Trainer 24 Power Window Troubleshooting
2005 f150 4x4 power windows ,interior lights a/c ,radio gauges are not working fuses are ok and already check for voltage and it has but still not working . It has something else in betwen..?......
Checked voltage where ?
The instrument control module (ICM) controls power to the power window system by activating or deactivating the delayed accessory relay.
  • Fuse(s).
  • Circuitry.
Vehicles equipped with remote keyless entry (RKE) have an illuminated entry feature, which enables the instrument cluster module (ICM) to illuminate the interior lamps (and if equipped, the puddle lamps in the exterior mirrors) when an unlock signal is received from the vehicle security module through the UBP network, or when any of the doors are opened. The ICM controls the interior lamps illuminated entry feature by activating the battery saver relay. When active, the illuminated entry feature will be canceled when any of the following conditions are met:
Instrument Cluster Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU is Defective Instrument Cluster Module REFER to Section 413-01 . B2499 Courtesy Lamp Output Failure Instrument Cluster Module Go To Pinpoint Test A . B2659 Courtesy Switch Fault Instrument Cluster Module Go To Pinpoint Test C . - All Other DTCs Instrument Cluster Module REFER to Section 419-10 . Do you have a professional grade scan tool ? If not your best bet would be to take your vehicle to a qualified repair shop .
Power window wiring diagram for 1998 Lincoln town car
Go to http://bbbind.com/free_tsb.html free wiring diagrams !
  • PERFORM Self Test to retrieve Diagnostic Trouble Codes. If no DTCs retrieved, GO to Pinpoint Test C .
  1. VISUAL INSPECTION CHART
  1. Mechanical
  2. Electrical
  • Lighting control module.
  • Circuits open/shorted.
  • Power distribution box Fuse D 40 for heated back window concern; Circuit Breaker 14 (20A), Circuit Breaker F (30A) or window regulator safety relay for power window concern.
  • Fuse junction panel Circuit Breaker 14 (20A), Fuses 6 (10A), 9 (5A), 15 (15A), Fuse 13 (10A), Fuse 4 (10A) or Circuit Breaker 12 (18A).
  • Scratched grid.
  1. If the inspection reveals obvious concerns that can be readily serviced, correct the concern before continuing with Inspection and Verification.
  1. If the concern remains after the inspection, connect the Rotunda New Generation Star (NGS) Tester, 007-00500 or equivalent, to the data link connector (DLC) located beneath the instrument panel to perform DATA LINK DIAGNOSTICS test. If the NGS responds with NO RESPONSE/NOT EQUIPPED for the driver door module, go to Pinpoint Test A . If the NGS responds with NO RESPONSE/NOT EQUIPPED for lighting control module, go to Pinpoint Test B . If the DATA LINK DIAGNOSTICS test is passed for the driver door module and lighting control module, retrieve continuous DTCs and execute self test diagnostics for the driver door module and lighting control module to retrieve current DTCs.
  1. If self test is passed and no DTCs are retrieved, go to Symptom Chart to continue diagnosis.
  1. If DTCs are retrieved for the driver door module, go to the Driver Door Module (DDM) Diagnostic Trouble Code (DTC) Index to continue diagnosis. If DTCs are retrieved for the lighting control module, go to the Lighting Control Module (LCM) Diagnostic Trouble Code (DTC) Index to continue diagnostics.
  1. If the driver door module cannot be accessed by the NGS tester, go to Pinpoint Test A . If the lighting control module cannot be accessed by the NGS, go to Pinpoint Test B .
You'll need more then wiring diagrams ! A good scan tool for starters .
Youl
How do i fix the driver side window switch
The thing to do first is have the vehicle hooked up to a professional grade scan tool an have it checked for DTC'S in the driver door module , an to see if the scan tool will talk with the module !
Then if no codes are present check for battery power an good grounds at the module ! You have to take the door panel off the door to get at the module . I have one of these modules out in my tool box , I got it at the auto salvage yard . $10.00
In order to control window operations, as well as other door functions, door modules must be powered up. Battery voltage is supplied by the rear fuse block, through separate circuits, to each door module. Each door module is separately grounded through a ground stake. Additionally, the door modules use these power and ground supplies to provide voltage and ground to their associated window switch, and to provide voltage and ground for door lock operations. The front door modules also use these power and ground supplies to power the window express up sensors, and for outside rearview mirror operation .
How to test computer controlled door locks
Electrical problem
Instrument cluster problem maybe . Without testing we'd only be guessing . Have seen this a lot at the dealer . The best thing would be to hook up a factory scan tool an check for DTC'S - diagnostic trouble codes first. The electronic's on these vehicles are complex to say the least . All the warning light's , gauge's etc.... are controlled by a module an data network . GM class 2 serial data buss. Power windows also are controlled by a module . DDM - driver door module.
Buick Class 2 Operation Diagnosis 1998
012 GM Class II Communications
• Driver Door Module (DDM)
• Passenger Door Module (PDM)
• Body Control Module (BCM)
• RR power window switch
• Window up and window down relays in each of the rear passenger window switches
• Window lockout switch
• Reversible power window motors in each of the doors (circuit breaker protected)
• LT DOOR CB 25A (System power for left windows)
• RT DOOR CB 25A (System power for right windows)
Your best bet , take it to the dealer .
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
