Question about UTStarcom Blitz Cell Phone
Keyboard keeps defaulting to numbers when texting
Configure received message settings:
1. From standby mode, press the OK Key [OK] to unlock the keypad,
then press the Left Soft Key [Message], then the Left Soft Key
again for [Settings].
2. Press the Directional Key up or down to highlight one of the
settings below, then press the OK Key [OK] to select it:
ENTRY MODE
Sets an Entry Mode as a default. For example, if Abc Mode is the default, its icon
will appear.
1. Select "Abc", "ABC" or "123" by pressing the Directional Key up or
down then press the OK Key [OK].
Posted on Jan 07, 2011
I have a ACER TABLET A1.801 with UK default keyboard but I cannot find how too or where is the INPUT KEYBOARD KEY or ICON ALSO ON ALT KEY I want to make changes to predictive text.Thanks David
you may want to see if you set back to manufacture original settings
all tablets have setting but if setup for uk default will you be able to read the instructions to fix the issues.
i would find the manufactures website, go support, see if they have FAQ section, or forum where you ask about the setting or the web site where you can get instruction manual and may be drivers setup for english setting after resetting tablet to manufactures settings
thank you rod
Mar 04, 2015 | Acer Computers & Internet
Tip
Sony Ericsson Secret Codes
SONY ERICCSON SECRET CODES:
On the main screen type
Sony Ericsson Secret Menu: -> * <- <- * <- *
(-> means press joystick, arrow keys or jogdial to the right and <- means left.)
You'll see phone model, software info, IMEI, configuration info, sim lock status, REAL time clock, total call time and text labels.
You can also test your phones services and hardware from this menu (main display, camera, LED/illumination, Flash LED, keyboard, earphone, speaker, microphone, radio and ******** tests)
IMEI Number: *#06#
Lockstatus: <- * * <-
Shortcut to last dialed numbers: 0#
Shortcut to sim numbers: On main menu type a number and press #
If you change the language from default to any other language, then it may be difficult to switch to default language. The shortcut is very simple. Just press < 0000
on Dec 15, 2009 | Cell Phones
Keyboard missing
Try deleting the keyboard's data in Settings/Applications. If it still doesn't work, use another keyboard app, and if you can't stand losing your default keyboard, restore your system.
Good luck.
Dec 18, 2013 | Samsung Galaxy Note 2
My baby has changed the language on my text input and i cant change it back,, how do i do it?
Xperia X10
To set the phone language:
1. From the Home screen, find and tap Settings > Language & keyboard > Select locale.
2. Select an option.
Note: The chosen phone language is also the writing language, if not selecting a specific writing language.
To set the writing language:
1. From the Home screen, find and tap Settings > Language & keyboard > Default input > Writing languages.
Useful tip:
* To change the keyboard when you're in a field that requires text or numbers, touch and hold the text bar, then tap Input Method and select an option.
* To enter special characters, such as å, just touch and hold the corresponding letter, and select an option.
Mar 08, 2011 | Sony Ericsson XPERIA X10 Cell Phone
I wantd my default.htc keyboard back
Hey there,
To change the keyboard that you use, when your cursor is on something that can be typed (like a text or email) touch the input window and hold it until a window pops up. Select input method and select your default HTC keyboard. That will now be your default keyboard used.
Hope this helps!!
Mar 03, 2011 | HTC EVO 4G Smartphone
How to activate NumLock as a default? My job requires that I work with numbers the majority of the time so I need to keep the NumLock active. However, each time I log off, the NumLock automatically...
A simple reg edit will do this
For current user:
  1. Start Regedit
  2. HKEY_CURRENT_USER\Control Panel\Keyboard\InitialKeyboardIndicators
  3. Change the value from 0 to 2
For all users:
  1. Start Regedit
  2. HKEY_USERS\.DEFAULT\Control Panel\Keyboard\InitialKeyboardIndicators
Jul 09, 2010 | Dell SK8110 Keyboard
NumLk issue
I found the following at:
http://www.freshmango.com/support/kb/office-business-programs/windows-xp/xp-numlock-issue-on-login-startup/
This should do the trick...
After some search I discovered that the Numlock control status can be controlled using a registry key which can be found here:
HKEY_USERS \ .DEFAULT \ Control Panel \ Keyboard \ InitialKeyboardIndicators
Simply change the value to either 0 for off or 2 for on.
  1. Start the Registry Editor
  2. Go to Start
  3. Select Run
  4. Type regedit
  5. Work through the tree to get to HKEY_USERS \ .DEFAULT \ Control Panel \ Keyboard
  6. If the key “InitialKeyboardIndicators” already exists then change its value to the appropriate number, if not, add a new key called “InitialKeyboardIndicators” with the appropriate value.
  7. Click OK
  8. Restart
For the lazier amongst you, simply copy and paste the code below in to a text file (in notepad), save it as "FixMySoddingNumlock.REG", close notepad and double click the file:
To make the Numlock OFF by default use: Windows Registry Editor Version 5.00
[HKEY_USERS\.DEFAULT\Control Panel\Keyboard]
"InitialKeyboardIndicators"="0"
To make the Numlock ON by default use: Windows Registry Editor Version 5.00
"InitialKeyboardIndicators"="2"
Oct 18, 2009 | Panasonic Toughbook 50 Notebook
Dell Keyboar Problem -
This likely is one of two issues. A BIOS setting, and can be changed in the BIOS setup utility accessible at startup.
Or ...
If you are sure you have no computer virus or a hardware conflict than you can modify this setting by editing the registry on the computer. Normally, the computer applies the user settings when the user logs on, but it uses the default user profile when it is first turned on, before the user has logged on. To turn this functionality off, the default user settings must be modified. The Keyboard entry contains user preferences as defined by choosing the Keyboard icon in Control Panel. Entries are found under this registry path:
InitialKeyboardIndicators REG_SZ Number set it default to 0.
If not:
* Run the Registry Editor (REGEDIT.EXE).
* Open HKEY_CURRENT_USER\Control Panel\Keyboard (If the Keyboard key isn't there, add it.)
* Double-click the InitialKeyboardIndicators value on the right. (If it's not there, select New from the Edit menu, then String Value, and type InitialKeyboardIndicators for the name of the new value.)
* Change the value to any of the following:
0 - all indicators off
1 - Caps Lock on
2 - Num Lock on
4 - Scroll Lock on
Or, combine them by adding the corresponding values:
3 - Caps Lock and Num Lock on
5 - Caps Lock and Scroll Lock on
6 - Num Lock and Scroll Lock on
7 - Caps Lock, Num Lock, and Scroll Lock on
* Close the Registry Editor when you're done.
All the change should take effect when next time you start Windows.
Aug 28, 2009 | Dell 0Y3740 Keyboard
Its typing numbers when pressed letters
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
  1. Click Start c01311982.gif , and type region into the Start Search field.
  2. Select the Keyboards and Languages tab.
  3. Click Change Keyboards .
    A Text Services and Input Languages window opens.
    Figure 3: Change Keyboard button
  4. Click Add .
    Figure 4: Add button
  5. Select the keyboard(s) you want to use and click OK .
    Figure 5: Add input language: US Dvorak keyboard selected.
    The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
    Figure 6: Keyboard tray icon
  6. From the Text Services and Input Languages window, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    Figure 7: Move up button
  7. Click OK . You can now use the new keyboard. If you find that the new keyboard works well and you do not want to use the other keyboard, repeat these steps and Remove the keyboard that you do not want from the General tab of the Text Services and Input Languages window.
Jun 10, 2009 | HP 386209-001 Keyboard
Keyboard keys malfunction
Hmmm,
1) May be you need to connect an external keyboard to your laptop and check whether the same happens.
else
2) Check whether the Num Lock is turned ON or OFF. If it is turned ON please turn it OFF by pressing the Num Lock on your keyboard.
else
3) Click Start and go to Control Panel In the left hand side click the Classic View. Now you will have a number of Icons. Double-click on Regional and Language Options. Choose the Keyboard and Language tab. Click Change Keyboards. In the Text Services and Input languages window, make sure the default language is set to English (US) Just below that check the Installed Services window to check whether the correct option is being shown.Click OK. else 4) Turn off computer. Remove both Battery and power cord. Keep pressing the power button for 20 seconds with no battery and power supply. This will make sure no static charges are present in the laptop. Put them back on and check the keyboard. else 5) Call the Dell Technical Support team to run Dell Diagnostics on the system to check keyboard functionality. They can help you replace the keyboard if it faulty and provided the laptop is covered under warranty Good Luck !!! Hope it works asap !!!
May 29, 2009 | Dell Studio XPS 16 Notebook
UTStarcom Blitz Cell Phone Logo
88 people viewed this question
Top UTStarcom Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
