Question about Dell Computers & Internet
I repeatedly get Program not responding messages
    Problem Solver:
  • 12 Answers
The first thing that I would suggest is to run a virus scan on your computer because viruses can slow down the computer and make then non-responsive alot of times. Also if you run alot of programs on your computer this can cause your computer to use alot of its memory. You can go to the START Menu at the bottom of your computer, then go to MY COMPUTER, then to CONTROL PANEL, then to ADD/REMOVE PROGRAMS. You will get a list of all the programs on your computer and how much memory space they are taking up. If you know of some that you no longer are using, delete them to free up more space. The more memory available the better and faster your computer will perform. After deleting, be sure to restart your computer.
Posted on Jul 18, 2009
    Novelist:
  • 109 Answers
Not much to go on here. Are you asking for condolences, or what to do about it? This message is caused generally by your machine having run out of resources. That could be swap file space, due to having run out of room on your hard drive, or swap file size set too small. Graphics card insufficient for what you are trying to do, especially if it is an on-board graphics card. Mostly due to not enough RAM installed. RAM chips are cheaper than they have ever been. See how much is in your machine, and then max it out by adding RAM up to the capacity of your motherboard. Temporary fix is try running less applications at one time, defrag your hard drive, add a program such as Advanced Windows Care (FREE on the net) and use it to maintain your registry, I would go for the RAM upgrade.
I need to know how to program remote
To program a new remote to the system; open door, turn ignition on, press and release valet switch one time then, press and hold valet switch. System will respond with a chirp. Now press lock button on remote. System will respond with a long chirp.Turn ignition off. Test system. Repeat for additional remotes.
Sep 28, 2012 | Dei 7641v Responder Remote 160xvl 7641
We cannot get the remote to program with our sanyo tv
If you have tried all the codes and none of them work your last option is to try a PowerScan. Steps are below.
Step 1: Manually turn off the device you wish to program (TV, VCR, DVD)
Step 2: Press and hold the appropriate device key (TV, VCR, DVD) until the red LED illuminates. This indicates that the remote is in programming mode.
Step 3: Press and release the power button. The LED flashes once and stays ON. Indicating that the remote is in PowerScan mode.
Step 4: Press either CH+ or CH- button repeatedly until the device switches on. The CH+ button searches upward in the code list while the CH- button searches downward.
Step 5: When the device turns on, press and release the OK button to store the new code and exit.
NOTE: If you press the CH+ or CH- again after the device turns on, the device will not be programmed and you will need to repeat steps 1 - 5.
Step 6: Press any other operable button (VOL+ or VOL-). If the device responds, no further programming is required. If the device does not respond then repeat steps 1 - 5.
Dec 23, 2010 | Brookstone 538744 Remote Control
Need codes for LG tv from rca remote thank u.
Hi! You can try using these steps for you to program your RCA remote control to your LG TV.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the device does not respond, repeat steps 1-6.
I hope this works for you.
Jul 13, 2010 | RCA Universal Remote Control
Cant program my rca remote for my LG tv don't have code
Hi! You try using these steps for you to program your remote control to your TV.
I hope this helps.
When I go from the organizer window to the edit window a get a message that says the program is not responding and the computer ends the program
try reinstalling the program from the CD it may be there is a conflict with an IRG or another software conflict. Sometimes by reinstalling the program it will repair the problem on it's own. If you have any questions just add a comment and I will respond as soon as I get it.
Thx
Aug 01, 2009 | Adobe Photoshop Elements 6: Windows
SWISSTECH 19INCH LCD - FAILING TO TO RESPOND TO
Hello my dear , I just want to now if I need a software to instal a new program on my lcd swiss tech, because the colores on it are damaged.
Jun 15, 2009 | Televison & Video
Dell 968 printer not responding message
is it connected to a pc correctly. Try clearing the print queue and ending the program. Turn the unit off and aftert a few moments on again to reset it. If it repeats error i woul uninstall it and reinstall it and start fresh
Apr 26, 2009 | Computers & Internet
How do i program my remote control rcu703sp and my
Programming a Device using Code Search:
1.
2.Manually turn ON your device (TV, VCR, Cable Box)
3.Press and "HOLD" CODE SEARCH
4.Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type
of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
5.Release CODE SEARCH.
6.Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
7.Once the device turns off, press and release ENTER.
8.With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
1.
2.Find codes for each device and brand below.
3.Press and "HOLD" CODE SEARCH.
4.Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable).
When the selected device button flashes proceed to the next step.
5.Enter the three digit code from the TV, VCR or Cable Box code lists.
6.Release CODE SEARCH.
7.With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using
another code number from the lists.
Mar 16, 2009 | RCA Universal Remote Control
Can't store anything lately
Hi, did you format the flash drive? If you are using windows, right click on the drive and select "Format...". You can repeat the operation a few times. If it's working, try to add your resume again. How old is the drive? Good luck!
Apr 25, 2007 | Memory Upgrades 1 GB USB 2.0 Micro...
Computers & Internet Logo
48 people viewed this question
Alun Cox
