Question about Pride Sundancer 3 Wheel Electric Scooter
Trouble shooting ideas as to why scooter no longer runs. Doesn't seem to hold a charge...
  • 103 Answers
Have the batteries load tested. They are probably bad.
Posted on Jul 23, 2009
Can I tighten the steering on a mobility scooter?
Hello Frank Archer,
That is more of a factor of the size
(and number) of the wheels...
I have been over the owners manuals on a couple of the scooters... It is ALWAYS a good idea to hold on tight on rough ground.
Do check out the trouble shooting section of your owners manual... better to be safe than have the wheels come off.
https://www.bing.com/search?q=mobility+scooter+steering+parts&form=EDGEAR&qs=AS&cvid=e2781cde3df84949b9ca4c714bccec86&pq=mobility%20scooter%20steerin
g&PC=DCTE
Aug 08, 2016 | Health & Beauty
Trouble with new batteries losing charge. I also purchased a new charger. It will run for awhile a couple of weeks then it will just keep losing power and just stop.
Number 1, always charge after every use. You can check if the charger is charging quickly, by turning on the scooter and watching the gauge when you plug the charger in. The gauge should climb up if it does not move then charger is not working. Make sure the charger is plugged into an outlet that is not shut off with a light switch!
Check out my Trouble-Shooting guide at Scooter Doctor App
Jul 31, 2015 | Mega Motion Elite 8
Why won't it operate?
How many flashes on green light. Count them and you should find in the trouble shooting section of your user manual what the problem is. Most cases you can sort yourself.
Jun 14, 2015 | Pride Celebrity X 3-Wheel Electric Scooter...
Battery charged, horn and light works, but scooter will not move
Is the brake engaged? That's the lever at the back. Needs to be in drive position. if yes then it could be the Wig-Wag control. Are there any flash code errors showing? check your user manual in trouble shooting section.
May 19, 2015 | Drive Medical Health & Beauty
DMA SCOOTER WONT MOVE ALTHOUGH BATTERY FULLY CHARGED
Are there any fault codes, flashing light. Check your user manual in the trouble shooting guide.
Have you disconnected charger from scooter as it will not move if it is still connected to scooter.
Apr 18, 2015 | Health & Beauty
Why does my 150 cc SUNL scooter not hold a charge? New battery is no different than original. It is a 2008 with 26 miles on it
Doesn´t matter the miles runned.
The battery is too old. chemicals inside are not capable to hold Current(Amperes).
Yo must change the Battery by a New one with the same parameters. (Volts,Amps, Size.)
2008 from now it´s too much time for a Battery, even unused.
Oct 21, 2014 | UPG 12V 12Ah SunL Tiger Scooter Battery -...
Doesn't seem to hold charge
right so it's one of two things, either the charger or the batteries,
can you try another charger ?
regards
Dec 18, 2012 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Just bought one of these and it seems like it doesn't hold a charge it goes pretty good and thanafter 15 mins so slow??
Battery powered vehicles like scooters and golf carts have trouble going up hill because smaller electric engines aren't powerful enough or made for nothing more than flat land. You could have a bad battery or the battery isn't being charged enough. I know someone that has a golfcart and it takes approximately 48 hours to charge full. You may want to check the manual about charging times.
Sep 16, 2012 | Razor E200/300 Electric Scooter Battery
My scooter battery won't charge. Felt mild shock or short when attempted to insert connector. That seemed to disable the charger because the charger powers on, but will not run the charge to the...
Make sure that the charger is fully connected to the scooter; ususally the controller lights will go slowly left to right to indicate it is charging. Make sure the charger is plugged directly into the grounded wall outlet, not into an extension cord or power bar. If the charger is not being recognized by the scooter, you may need to replace the charger, or at least the power cord to the charger.
If your scooter has been sitting unused for a while? If so, the batteries might not charge anymore and will need to be replaced. Contact the manufacturer for a service call or troubleshooting over the phone.
Nov 04, 2010 | Pride Mobility Products Go-Go Elite...
Batterys will not hold charge
Hi kevinsharpe8;
Right off the top of my head I would suspect the charging circuit. The way to check this is to measure the voltage at the batteries while they are on charge. The voltage reading when they are supposed to be charging should be higher that what you would read at the batteries when they are not charging.
These charging circuits are not complicated and any electrician type should be able to trouble shoot the circuit and find the problem
Hope this helps Good Luck Loringh PS Please leave a rating if appropriate thanks
Nov 20, 2008 | Saws
Pride Sundancer 3 Wheel Electric Scooter Logo
129 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
