Question about Echo Garden
Please advise oil/petrol ratio...air gap ...plug
Please advise oil/petrol ratio...air gap ...plug gap for Echo 631 chainsaw Thanks
  • 76 Answers
Hi
follow the link there are several manuals there for Echo chain saws
http://lawnandgarden.owneriq.net/manuals/mfg/echo/echo_chainsaw_product_list.html
http://www.echo-usa.com/pdf/documentation/CS300034003450efT1E_060402_1.pdf
on page 4 it says the types of oil and petrol
hope it helps
appreciate some rating form you.
thanks
Posted on Jul 18, 2009
What is the fuel oil ratio per litre for a husqvarna 535rxt strimmer
If it is 2 stroke, take petrol /fuel and mix it with preferably synthetic2 stroke oil.
Ratio is usually 10L petrol mixed with 200 ml or 2 stroke oil, that is the best result, used it on my chainsaw, strimmer, moped, working for years without a glitch.
Jul 20, 2015 | Husqvarna Garden
Echo chain saw won't start tried new gas ran then quit plug is clean
check air, gas and oil ratio.... check high voltage to plug..
Sep 21, 2013 | Echo Garden
Oil to petrol ratio
25 to 1 get 2 stroke oil from a hire shop only need a one shot mix, will do up to a gallon.
May 02, 2012 | Mcculloch 16" Electric Chain Saw Mcc3516f
What is the oil to petrol ratio for an Echo Saw?
Oil / gas should be in the ratio 1 to 50 or 2%.
This is 20mL in 1 litre or 2.6 fl oz per US gallon
Aug 01, 2011 | Echo CS400 18" Chain Saw
Need gas misture ratio for trimmer SRM2501
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Echo Garden
Need to know the gas to oil ratio for my feather lite weedeater. Model FL21
"Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more."
The above excerpt is from the Echo FAQs (6) here:
http://www.echo-usa.com/faqs/
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 17, 2010 | Echo Rapid Loader, Trimmer Head
What type of fuel mixture do I use for 20760 Homelite gas trimmer?
Most likely not the answer you are looking for but here is a shot:
Pick up a bottle of the Echo brand 2-cycle oil. It will say "Extended Life" on the labeling. This is meant to run in Echo products, but it is a very FINE and well engineered oil. Mix it according to label directions for 50:1 ratios. (2.6 Oz. to 1 Gal. Gasoline)
When mixed at this ratio it provides MORE than adequate engine protection for ALL 2-Cycle engines, including those that run in 40, and 30:1 ratios.
I mix one 2-cycle tank to label instructions on the Echo oil for 50:1. It handily runs in my Echo chainsaws, non-echo trimmer, Poulan Pro leaf blower, etc. They all run different ratios, but THRIVE on the Echo mix without as much oily residue and smoke to boot!
CAUTION: I do not know of ANY OTHER MAKE of 2-cycle oil that CAN DO THIS *SAFELY*.
Remember:
Always mix your 2-cycle fuel starting with *fresh* gas.
Mix only that which you can use in 30 days.
Use 89 Octane fuel to make your mix in small piston 2-cycle engines.
Clean and re-oil intake filters @ every 10 hrs. operation time. Check and re-gap your plug when you service your filter!
DRAIN unused fuel from tank back into gas mix container. Restart and let engine idle to run any remaining fuel out of engine and carb. Storing fuel in ANY 2-cycle longer than two weeks is going to gum them up and nothing short of a carb rebuild will get them sputtering back to life again!
May 08, 2010 | Homelite Mighty Lite Lawn Trimmer
What is correct fuel mixture for Echo CS 6701 Chain saw?
Oil Mix Ratio:
Lou
May 08, 2010 | Echo CS600P Gas Chainsaw 20 Inch
What is the 2 stroke mixture ratio for a McCulloch 338 chainsaw please
It is 40:1 (see below)
If this helps, pls leave feedback, if not let me know and I'll try and help some more!
~~Technical Specification~~
~ Engine
Capacity 38cc
Stroke 32mm
Idle Speed 3000rpm
Max speed 13000rpm
Power 1.6kW (2.15hp)
~ Ignition
Manufacturer Walboro
Type of ignition CD
Spark plug Champion
Electrode Gap 5mm
~Fuel
Unleaded Petrol mixed 40:1 with 2-stroke engine oil
Capacty 0.38 litres
~Noise
Max 111DbA (as loud as a very loud Nightclub get those earplugs in!!!)
~Weight
4.7Kg (trust me that is very light for a chainsaw)
~Chain Bar
Length 14" (36cm)
~~Safety~~
As with all chainsaws it is essential to wear full protective equpment, and be aware of others around you. You should wear
Safety Hard Hat with Face shield
Safety Googles
Ear plugs/Ear Defenders
Snug Tight Fitting Clothing
Safety Footware with steel toecaps and non-slip soles.
Heavy Duty Rigger Gloves
Leg Chaps
Jan 28, 2010 | Air Tools & Compressors
Need fuel mix ratio & plug gap 4 husky 154 sg chainsaw
Hi there, No problem.
Recommended fuel mix ration if using Husqvarna brand premium Two-Stroke Oil is 50:1. If using another two-stroke air cooled engine oil, you should use 25:1 fuel:oil ratio.
Regading the spark plug, the recommended plug is a Champion RCJ7Y with a plug gap of 0.5mm (or 0.020 inches).
Mar 14, 2009 | Husqvarna Garden
Garden Logo
343 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
