Question about Electrolux Guardian Bagged Canister Vacuum
Power cord plug broke and cord went back inside.......how do i open??
  • Anonymous Mar 17, 2014
    the end of cord broke and now cord is stuck inside the vacuum. How do I open the canister. I can't find my manual
  • 75 Answers
Call your local Electrolux office. Trying to fix it yourself will void your warranty. If you need any assistance call 570-326-1731 and ask for Liz, I will be happy to assist you if I can.
Posted on Dec 27, 2007
The plug prong broke on my Electrolux Epic 6500 SR vacuum. I cut it off and was going to replace it with a new plug. However, I mistakenly rewound the cord and it went all the way into the body.
You will likely have to install a new cord reel. Cord reels have a long tightly wound steel spring which can fly out causing injury if you attempt to take it apart.
Mar 04, 2017 | Vacuums
Why does my plug get extremely warm or hot?
Inside the wire, several strands of wire are broke. Heat is caused by less strands of wire that have to carry more current in amps. This is a safety and fire hazard. Cut the old plug off by cutting the cord about 2 inches away from the plug. Strip the wires carefully. Do not cut or break off any strands of wire. Install a new plug. Make sure you buy a round plug that has a round opening for your round cord. A lot of plugs are for flat type of cords only.
Oct 24, 2015 | Rainbow E series Canister Wet/Dry Vacuum
HOW TO REPLACE CORD BROKE INSIDE UNIT CAT TAKE IT
you know the cord is broke? and you wish to remove and replace the broken one? well it has to be opened to remove or reconnect the broken wiring. is there screws attaching the removable parts in order to get to the broken cord? recommend you locate broken wires and reconnect each wire to its color either white and black. and use electrical tape to cover each wire reconnected.
Mar 12, 2010 | Hoover Elite U5061-900 Bagged Upright...
How do I open a Kenmore 116 Vacuum?
You shouldn't need to remove the cord just to put a new plug on. Just cut the end off about 2 inches back, strip the outer insulation and the wire ends and install the new plug. Make sure there are no stray strands of wire hanging out from under the screws. I always solder the ends, so that I am dealing with a solid wire rather than twisted strands.
Sep 19, 2009 | Kenmore 25512/ 25513 Progressive Canister...
No power from Kirby!!
Determine if the headlight works before anything else. If the light works but the motor won't you have power thru the vac and the problem is internal possibly motor brushes... or a loose wire on the inside connecting to the switch.
If the light goes out is likely a switch or cord problem. Switches on these vacs break more often than cords. What you see on top is the switch button, not the actually internal switch, however a switch does not normally fail while the vac is running, that sounds more like a loose connection or a bad cord.
So isolate the cord. Unplug it at both ends and plug lamp ( or test meter) into the cord into the cord and gently wiggle where the plug end meets the cord. If the lamp goes on and off the issue is the cord. You can buy a replacement specific to the Kirby series and plug it in yourself. If this s does not isolate the problem, take it to a service center. Kirby is very intricate inside.
Sep 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Wont power up
first in could be that your power cord has been bent and twisted too much and the wire has broke inside the cord or the wires could have come off the motor or the motor could have fried.
Jul 30, 2009 | Hoover F5858-910 SteamVac Vacuum
Opening up Centrixx V6
I live in Israel. My vacuum cleaner broke down. Where can I fix it in my country.
Apr 16, 2009 | Dirt Devil V6 Canister Vacuum
Bissell 6900 stopped working how do I open the thing?
Bissell 6900 Digipro ON OFF Power Switch failed. I found the wire connectors for the power switch were corroded. I fixed this by soldering the wires directly to the terminals leading to the motor. To access the circuit board and the on.off power switch I pryed off the cover for the on /off power switch and the cover for the cord retraction leaver. The covers are held on by two tabs that extend under the red cover on the top of the vacuum. Push the switch cover away from the red cover while prying the cover upwards, You may damage the two tabs on the switch cover, as I did, but afterwards, the cover went back in place and appears to work okay. WARNING: This is a home made repair of a 120 VAC circuit. If you are un qualifued to do this repair you face serious risk of a faulty solder and fire inside the vaccuum cleaner. 4fd9446.jpg78baa14.jpg
Jan 26, 2008 | Bissell 6900 DigiPro Bagged Canister...
DYSON DC05
My friends Dyson DC05 was loosing suction and then it stopped altogether one day. When she took the filters out there was black soot in them so it was obvious that the motor had burnt out. I think this happened because she wasn't cleaning the filters regularly (go do yours now!) I replaced the motor myself and wrote a guide with photo's at www.tasweb.org
Dec 11, 2007 | Dyson DC05 Cylinder Bagless Canister...
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
125 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
