Question about Cameras
DIGIgr8 3.1Megapixel camera/video
I have the "DIGIgr8" 3.1 mp video/picture camera. my problem is the when i insert the 8gb memory card, then turn on the camera...it freezes and wont go past the blue start-up screen. when i take the card out it, it works perfectly..but of coarse i cant take a pic or video. only when the card is in it wont start up any help?
I have a DIGIgr8 3.1mpvideo/picture camera i have lost my driver can some one tell me were i can get one all is well with the camera and video but can not get my pictures on to my computer thanks for any help pat.
Posted on May 24, 2010
GE w1000 cannot save pictures directly to memory card.. is there any solution regarding this matter?? any suggestion will be more appreciated.. tnx and God bless!!!
What type and size memory card? The W1000 works with SD and SDHC cards up to 8GB in size.
What happens when you try to format the card? Have you tried another card?
Feb 22, 2013 | GE Recertified - W1000 Black 10.1 MP...
Memory full after about 20 pictures should I be able to take more I come back download and it still only lets me have about 20 pictures each time.This with my 5105.
The number of photos you can shoot depends upon the size of the memory card, you must have a small memory card in your camera . Try inserting a 4Gb to 8Gb memory card in your camera.
Oct 13, 2012 | Vivitar Vivicam 5105s Digital Camera
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I...
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
You need to use SD cards, 2GB and smaller.
Sep 30, 2010 | Kodak EasyShare DX4530 Digital Camera
I bought this camera but don't know how to operate it. No clear instructions with it. Where can I find a manual? It has a memory card that inserts into the bottom of it. I turn the power on and take the...
Please see my previous post concerning the Vivitar 8010. Also, you need an SD Memory Card for this camera. The entire Owner's Manual can be found online at www.vivitar.com/files_products/12/8018 User Manual.pdf. Hope this helps. It's a fun little camera!
Sep 19, 2010 | Vivitar ViviCam 8018 Digital Camera
When I attempt to take a picture I receive this message on the screen: Memory Full Insert a memory card to transfer and take more photos. I have a memory card already inserted into the camara, and...
The camera only holds one picture, and that only until you turn the power off. To take and store pictures, you need a memory card. The 8025 uses SD and SDHC cards up to 8GB in size. These cards are available at just about any department, electronics, and office-supply stores.
Aug 07, 2010 | Vivitar ViviCam 8025 Digital Camera
Card Cant Be Read
Same thing happened to me, after taking some pictures of a christening, connected to card reader, it wasn't recognised by card reader. I re-inserted it in camera and got card error, tried some softwares to extract pics but for nothing!!! I'm very dissatasfied!!
May 25, 2010 | SanDisk Ultra II 8GB Secure Digital High...
I have a Kodak Easy Share C310. It keeps saying that the internal memory card is full. The card is the camera is 200 photos yet it is only showing the original 16! Thanks, Kathy D
"internal memory card is full" There is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the Picture Size setting you have selected on your camera.The following are approximate number of pictures you can take at each setting: 4.0 MP: 16 pictures 3.1 MP: 18 pictures 2.8 MP: 20 pictures 2.1 MP: 29 pictures 1.1 MP: 48 pictures Internal Memory?the camera always uses internal memory, even if a card is installed. Auto (default)?the camera uses the card if one is in the camera. If not, the camera uses internal memory Image Storage Choose a storage location for pictures and videos. To correct the issue your getting follow this steps: 1.Press the Menu button. 2.Press to highlight the setting you wish to change, then press the OK button. - The settings you need to look for is Image Storage 3.Choose an option, then press the OK button. - The option you need to choose is Auto the camera uses the card if one is in the camera. 4.Press the Menu button to exit.
Nov 15, 2009 | Cameras
Canon FS200 won't fully initialize 32 GB SDHC card
I heard about that quite a lot of time,in deed. But, I personally haven't load 16 or 32 GB memory card in Canon FS200. At the very begining, I was thinking of using 16 GB SDHC card instead of built in 8 GB memory. The shop assistance don't advice me to buy more than that 8GB because he also know that problem. So then, I am still using with 8GB untill now.
Jul 05, 2009 | Canon FS100 Flash Media Camcorder
I cannot upload pictures/ videos from my PNY 8GB memory stick.
The newer large capacity cards in cameras designed for smaller capacity cards seem to have trouble interfacing with our computers. The best best is to get a high speed firewire memory card reader and attach it directly to your computer.
This should allow your computer to recognize your card and also allow you quicker downloads.
May 22, 2009 | PNY 2GB Secure Digital Memory Card
Cameras Logo
497 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
