Model # wfmc2100uc/01
Please check Is the washer door or lid closed?
1. If yes, does it filled with water?
2. if no: Please contact the manufacturer to replace the door lock switch
You can check the following things in your washer:
1. Is the washer door or lid closed?
a. If yes, does it filled with water?
b. if no: Please contact the manufacturer to replace the door latch.
And if it is not filling properly then there is a water supply issues like: hot or cold faucets closed or not open completely, hot and cold hoses reversed, kinked or pinched fill hoses, plugged inlet screens or insufficient water pressure
SOURCE: I want to buy an
The manual is available from Bosch. Start here: http://www.bshappliancecare.com/Bosch/ and select Check your instruction manual in section 1 (Browse online help). Then search on your model, WFMC2100UC/01 . The document is a PDF.
The direct link appears to be https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=qlho2Zacdcso0pdmdb---0XX&UMOBID=qlho21bcdcso0pdmdb---0XX but I'm not positive the link will work. Javascript links don't always translate into good URLs.
I hope this helps.
