Question about Olevia Televison & Video
I have an olevia 42inch lcd and it power off and would not turn on again, any solution?
    President:
  • 1,077 Answers
Most TVs have " Protection Mode ". When the TV detects a bad circuit board, it automatically turns itself OFF. That way it can protect the other components from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common problem are the power supply for the screen itself. Most manufactures call it a Blacklight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 18, 2009
42inch lcd olevia TV m-242-511 blue light stay's on
The main board fault. Contact the authorized service centre for Olevia.
Gopakumar Gopalan Google
Apr 01, 2014 | Pioneer PDP-4270HD 42 in. Plasma...
I have a Olevia lt37hvs, When i plug it in the blue(olevia)light comes on then goes off and the screen will be blue for 5-6 second then go black for 1-2 seconds then screen goes blue again and it just...
tried to connect again the supply for main board and disconnect the supply for the inverter board of back light. and turn on the tv, if the indicator stay the inventer board was the cause of voltage drop at the power supply board.
Sep 08, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 542-b11 LCD HDTV won't turn on. Blue light blinks twice
My Olevia 42" television is several years old. In March of 2012, the infamous "TV will not power on" problem started.
The blue LED light on the front of the TV would go off for a split second, then light up again. The television would not start.
If you are handy with small tools and a soldering iron, you can change the capacitors on the power supply. My Olevia is a model 542-B11.
I bought the repair kit off eBay from seller: sghill99
As of this writing, the seller has sold 37 of these kits. The title of the auction is: Repair Kit, Olevia 542-B11, LCD TV, Capacitors
And if the url is still active, it is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230554940338&ssPageName=ADME:L:OC:US:3160
I made the repairs in March 2012 and it is now August 2012 and the television is still working great. It is turned on and off several times every day.
Oct 25, 2011 | Olevia LT42HVi 42 in. LCD Television
Olevia 37" LCD TV will
my olevia a 232 s12 2nd hand tv . gift from a relative wont power on .just had the blue light on.i was able to reset my 32 inch olevia by pressing and holding down the power button much like a computer to reboot.might work for you.
Aug 20, 2011 | Olevia LT32HVM 32 in. LCD Television
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Won't always turn on
These olevia tv's were only made to last a few years. the company has gone out of business. they took the money and ran.i also have the same exact problem. the power supply board needs replacing and i can't find one. repair shops want almost 300 to fix but it isn't worth it. thow away or if your lucky enough to find a power board fix it yourself for around 100. i t k mine apart seems easy to fix.
May 26, 2009 | Olevia LT23HVX 23 in. LCD Television
Olevia LT 37 HVS HDMI PORT
You need to take the unit to an authorized repair shop to have it
check and correct it , looks like the power supply section got affected by the sudden change of voltage and damaged an internal part, hope this helps , AJ
Jul 02, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT23 23in. LCD/TV
I had the same prob, but found out that the problem with the Olevia lcd tv's on most models not powering up is because of failure of capacitors on the power supply board that I do believe is due to excessive heat and lack of ventilation.
I took the tv apart and got access to the main board and just by looking at the capacitors I could tell which one were the bad ones..
I will show some pics that I borrowed during my repair, hope it helps as reference as it did to me.
I replaced the bad caps with new ones that I bought at a computer parts store.
Now I got my lcd tv back ON but this time I added a internal cooling fan for better air flow that will reduce this malfunction from happening again.
Hope this helps.
Oct 14, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Power problems
I have a 32'' olevia 232v hdtv. I had a similar problem where the tv stays on less and less as you use it longer and it gets warmer. I called customer service and they explained that its most likely a problem with it is doesnt have enough power to run well. They said turn the TV off, then hit the master turn off switch in the lower back of the tv, then unplug everything from the TV, then unplug everything from the wall. Then after 3 or 4 hours, plug all back in and try again. Then they said if i still have a problem, call customer service at 1 866 9 olevia
Sep 29, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
115 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
