Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic pt-53wx42f I replaced the ic's and
Panasonic pt-53wx42f I replaced the ic's and resistors.now the tv will work fine for a few minutes the shut off and light blinks 3 times.Any ideas
  • ganda05 Jul 18, 2009
    Where did you get the ic's and what did you pay for them?
  • John Snow
    John Snow May 11, 2010
    I have had this exact problem and it was the STK IC's that I bought were cheapies and they could not handle the current. I replaced them with the panasonic IC's and it came back to life. You can respond to this post and I can help you if you have any further questions.
  • 100 Answers
Check for defective C945 transistors and diode
Posted on Jul 18, 2009
Colors will not align on the crosshairs...modelpt-53wx42f
Convergence Ic's must be replaced along with and burned bias resistors.
Apr 02, 2010 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT-47WX53 has intermittant convergance issue
I would chack the solder connections at the convergence ICs first. Since the set "recovers" on its own, it suggests a connection issue rather than a defective component. Also, if the ICs were installed without sufficient heat sink compound, this could happen as well. Look at low valued resistors in the area of the ICs for signs of overheating as well.
Keep us posted on your progress.
Dan
Oct 19, 2009 | Panasonic Televison & Video
Panasonic PT-53WX42F does not turn on, gives single flash code
my tv had the same problem and the B+140 was low. When I measured it, it was 89volts unfortunatly led me to the Flyback tra$former. after alot of troubleshooting work, I realized that the primary is short circuited. Also the horizontal output xsitor heats up alot on start up, thankfully it doesn't blow :)
I've had panasonic flybacks do this before to me. I havn't replaced my Flayback yet but when I pony up the $65.00 I expect (and pray) the TV to work fine. There is an off chance that something like the splitter or the foucus block caused this failure, but I doubt it.
Jul 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
PT-47WX49E just shut off
maybe the convergence resistors? sometimes when the ics blow a resistor or a few blow
Jan 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
RESISTORS
The value of those resistors is 0.27 ohms 5% 1 watt.
Click here to find the resistors.
Jul 21, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic 47 inch Projection tv PT-53WX42F
Sounds like your convergence chips are going. Unless you are real handy with soldering iron I would suggest having a tv repair shop service it(probably cost $200-300). If you are handy then I believe the chips you need are Sanyo STK392-110. There should be 2 of them. be careful if you order them online, there are lots of chinese knock-offs out there.
Apr 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Resistor
electronix.com or matelectronic.com should have that resistor. Be sure to specify flame resistant 5% tolerance that is a convergence resistor so it needs to be flameproof and install it up off the board like the origional was.
Feb 18, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42F Picture Problem. Color Distortion.
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
322 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
