SOURCE: THE SCOOTER MAKES A HIGH PITCH NOISE WHEN THE KEY IS TURNED ON
The buzzer is a piezo-electric device that is the "horn" for the scooter. It also will alert when the scooter is in reverse, if this option is programmed into the scooter. It receives its power from the PC board or console board which is located inside the top of the shroud at the tiller, where the thumb paddles that direct the scooter are located. If liquids have reached the board, or if condensation has affected the board, the circuit that controls the buzzer may have shorted causing it to come on constantly.
Opening the top of the shroud is fairly simple. Remove about 6 screws holding the clamshell cover together, remove the speed adjust knob, and it should come apart. Inside you'll see a PC (printed circuit) board, green in color with lots of small electronic parts embedded on it. The buzzer is also inside, usually about the size of a marshmallow and black in color with tiny holes to let the noise escape. There will be two wires leading from the buzzer to the plug-in at the PC board. Unplug the buzzer and the noise will stop, but you won't have use of the "horn" at all. Replacing the PC board can be done by a certified Pride tech, but it will probably cost you about $150.00 for parts and labor.
Hope this helps.
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
SOURCE: how do i remove the pride legend classic xl8 seat
hi, be careful here as it can make your back ache,
now there is a lever to the right of the seat, pull it up towards you and
turn your seat 90 anticlockwise, so the seats not facing the control panel, at right angles, you should now be able to lift the seat , take great care here if you have back problems in the past as some seats are quite heavy.
Regards
GeWiz.
Testimonial: "thanks"
SOURCE: I wanted to get a copy of a manual for the Pride
you can download from this site http://www.pridemobility.com/international/UK/ukownersmanuals.asp
plz rate me
Testimonial: "Brilliant and so fast. I am very pleased thank you so much. D."
SOURCE: I have a 3yr old
Kay the status light flashing indicates a problem. Count the nunber of flashes and your manual should tell you what the error code means. Also check the freewheel lever and make sure it is drive position. Without knowing the number of flashes I can't tell you what the problem might be. Hope this helps
Testimonial: "freewheel lever! thank you very much"
