Question about Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model
Intek engine runs poorly under load and when warm
I have a 42" Craftsman mower with a 21hp Intek engine. It starts normally and runs great for the first 5 minutes. Then under load it starts missing terribly. Spark looks ok, pulling the choke out half way seems to help smooth smooth the engine but with strong unburned fuel smell. Any suggestions?
  • 130 Answers
If you have a ohv ajust valves and you might have to rebuild carb.
Posted on Jul 18, 2009
Riding mower won't start, new starter, spark plugs an fuel filter. What should I check next?
If it's carbureted, make sure the bowl float isn't stuck.
Another possible idea, and not saying that this is it, but many small engines have a small sensor that will hour allow an engine to run without having an adequate oil level.
My 21hp briggs engine won't start if I'm only 3oz low..
Apr 27, 2017 | Craftsman Garden
Why does it backfire on warm restarts?
readjust the valve clearances
B& S engines are renowned for stretching the valve stems during use
creates hard /no starting when hot
check for coil wire touching the engine and shorting out
Nov 14, 2015 | Craftsman 42 In. 21Hp Briggs & Stratton...
Why is my 2012 21hp sears 42" lawn tractor blowing smoke
If it is a V twin Kohler engine, you may have a blown head gasket. It is a common issue. Great engine but has this one issue. Kohler has a head gasket kit with improved head bolts. Torque specs are included. You will need a inch pound torque wrench and common hand tools.
Jun 14, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
17.5 intek engine will not start, engine has fire and gas. craftsman LT2000 42 in deck lown mower
Is the flwheel key ok? Or you may problem like me. Pull
valve cover and see if both pushrods move.
Jul 19, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman mower with the B&S 21hp Intek OHV motor, it starts fine but when you go to engage the blade or go forward or backward or release the parking brake it will die unless you disengage...
Check the switch on the seat, of all places. There's a safety switch on the seat that will kill the engine if it's not engaged when do anything other than start and run the engine.
If the switch checks out, get back with me.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 21hp, 48" lawn tractor, electric start, automatic trans
The alternator is built into the starter. Check with a volt meter to see if you have at least +13v while mower engine is running. Could be a bad battery.
Jun 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motor chokes and misses under moderate load and loses power
Sounds to me as tho it might need a carburetor adjustment, providing there is an adjustment screw on the carb. Sounds like the engine is running a bit lean. Did this problem occur right after the carb cleaning, or was it there in advance? Is there a fuel filter that might be clogged?
Jan 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I craftsman 20 hp twin mower quits after waarm up
SOUNDS LIKE A FUEL PROBLEM OR DIRT WHAT OTHER SYMPTONS DOES IT HAVE
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model Logo
890 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
