Question about KitchenAid KSRP22FNSS Side by Side Refrigerator
Food freezing in the refrigerator side
The recommended setting in 37 degrees for the refrigerator, but if i leave it to that food freezes, especially in the back of the refrigertor. I have set the setting to 40 now but not sure if i should put it back to the recommended setting.
  • joannsulz Apr 05, 2008
    My Amana refrigerator freezes food even though the dial is set at 3.
  • Anonymous Mar 30, 2014
    Food in top shelve keeps freezing
    Problem Solver:
  • 11 Answers
Hi! you already the solution of the food freezing problem.the cause was occurs because the thermostat was not duly recommended for calibration.
Posted on Nov 20, 2007
What should the temperature inside the refrigerator be, I have it set at 37
On the fresh food side you have it set at the proper temperature. Most thermostats have a scale from 1 to 7 or 9. If you set the thermostat at 5 this equates to about 37 degrees. Thermostat do lose sensitivity after a while and need to be replaces. The switch inside the thermostat wears out and the sensing bulb sometimes loses the fluid inside the sensor and the thermostat stops controlling temperature. So sounds like you have it set properly.
Oct 14, 2014 | LG LFX25960ST Stainless Steel French Door...
Fridge freezing up
Set your Ref/Freezer per the following:
36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
You have to wait about 4 hours for everything to stabilize. If you are still having ice forming inside the freeezer then the rubber seal around the door is probably the problem. If they have a split, tear or crack, etc. it will let warm moist house air into the freezer and turn to ice as it cools. If this happens in the refrigerator it'll turn to water and collect in the bottom of the frig. New seals can cost around $60 per door.
If you pack too much food in the unit it may also cause freezing because the air needs to move around in there and food shouldn't block the vents in the back walls of the unit.
Hopefully this helps..
Nov 23, 2012 | Spartan Showcase Self Service Cigarette...
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Sometimes when the refrigerator temp is 37* some of the food will get frozen.
Your thermostat is faulty. The vegetables cannot freeze at 37 degrees. It will not freeze until it's at 32 degrees. The sensor is wrong as it is impossible to freeze anywhere above 32.
Sep 08, 2011 | LG LFC23760ST Side by Side Bottom Freezer...
Hi my name is veronica my problem of my kenmore elite refrigertor is not cold enought...i want to know what is the tempertaure that need to be on
Problems with Temperature
If the refrigerator or freezer is not cooling properly, check temperature settings and air vents and ensure there is adequate room for proper airflow. Factory-recommended temperature settings are 0 degrees Fahrenheit (-18 degrees Celsius) for the refrigerator; and 37 degrees Fahrenheit (3 degrees Celsius) for the freezer.
If you need to adjust the temperature, do it one degree at a time and wait 24 hours before making additional adjustments. Check the air vents and make sure nothing is blocking them. Finally, if your refrigerator or freezer is too full, there will not be adequate room for air to circulate and cool properly. If these all check out, the problem could be with one or more compressor components and will require professional repair.
Have a nice day : )
Sep 05, 2011 | Refrigerators
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food.
Step 2
Place your magnetic thermometer in the refrigerator.
Step 3
Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
Step 4
After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
Step 5
Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
Aug 09, 2010 | Hotpoint Refrigerators
Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model.
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Produce is freezing in refrigerator
might need thermostat replaced. use thermometer at different thermo settings to see if any changes
Dec 31, 2009 | Maytag MFI2568AE Side by Side French Door...
Water filter froze solid
Your refrigerator compartment temprature is below 32 degrees and freezing your water in the filter. Adjust the thermostat setting to a higher temprature setting using a thermometer in the referigerator as a refrence. 34-37 degrees is a good temprature range to keep food fresh.
Jul 31, 2009 | Refrigerators
KitchenAid KSRP22FNSS Side by Side Refrigerator Logo
715 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
