Question about Refrigerators
Our Frigidaire 18.4 cubic foot top freezer/frigerator P/n241543906 has water pooling inside of the top of the refrigerator also vents in freezer are hot. What could be the problem?
  • 146 Answers
Hi my is Paul. well the drain looks like it Plugged. If you look in very back there should be a small hole that one you need to unplug in the freezer compartment. that hot vent well that could be the defroster. if you are maintaining a good temperature do not worry about it. you can check the temperature it should be 45 in the frig and Zero freezer or below 30. Hope this helps
Posted on Jul 18, 2009
  • 10,865 Answers
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
The refrigerator never cycles off The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired.
How many cubic feet in model FRT18SJGW2?
Katy,
It is going to be in the neighborhood of 18 cubic feet. Most manufacturers will put the cubic foot size in the model number but it can be a little smaller and it could go a little higher like 18.2 or 18.3 cubic feet and they would still call it an 18. Hope this helps!
Jun 26, 2015 | Frigidaire Refrigerators
What is the cu ft for frigidaire upright freezer mfu21m3gw1
Thank you for your post, friend!
I see you would like to know the cubic footage of your Frigidaire freezer. Based off the model number you have provided it appears that you have a 21 cubic foot freezer. Hopefully this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Freezers
I have a 7 year old 21 cubic ft., top freezer Frigidaire refrigerator. There is always water dripping down the back of the inside of the fridge, which then pools in the well in the bottom. It seems like...
syringe the tube with clorine bleach.dry out the interior then cover all food to cut down on condensation,although most freezers are "frost free"the fridges ARE NOT.so most of the problems are condensation.....
Sep 02, 2010 | Refrigerators
Water is leaking into refrigerator. I turned off
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 12, 2010 | Whirlpool Refrigerators
I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
Apr 18, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Pool Sand Filter
The volume of a 24x4 pool is 1809.6 cubic feet [Volume=pi x radius squared x height, or V=3.14159 x(12x12)x4], and the 18 foot pool is 1017.9 cubic feet [V=3.14159 x (9x9)x4]. When you multiply the number of cubic feet by the conversion factor of 7.48 gallons per cubic foot, you come out with 13,536 gallons versus 7614 gallons. Since the volume is nearly double, I don't think the other filter will cut it for very long. Is the top that is cracked in the valve body or the top part of the tank? It might be cheaper and easier to just replace the defective part in the long run than to use an undersized filter that will die prematurely.
Apr 15, 2009 | Hayward Pro Series 18" Above Ground Pool...
Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Jan 11, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Nov 12, 2007 | Frigidaire Refrigerators
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
