Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Motor keeps shutting off
There's a click, the fan runs for about ten seconds, then a click and fan stops...a few minutes later cycle repeats. Frozen foods are melting
  • 358 Answers
It's a problem very common on this brand of refrigarators that the compresor relay goes bad and needs to be replaced(located on the side of the compresor under the black plastic cover).
Posted on Jul 18, 2009
LEC8858EQ0 starts and then shuts off
You have a problem with the motor overheating. Replace the motor and you should be good to go. Here is the motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 08, 2012 | Whirlpool Dryers
I have a dayton hanging furnace that after a few minutes the fan stops and burner keeps burning then a few minutes later the fan starts again and keeps repeating this cycle. model 3E845. thanks.
On the side of the heat exchanger is a fan Klixon that turns that motor on when the temp exceed 110f on the side of the heater. maybe that thang is going out or your fan motor needs oiling and is cutting out on overload. Next to the fan klixon is usually a limit. Both look the same. The fan klixon will have a marking stamped into the metal such as F-120 the limit will have L-240.
Dec 28, 2010 | Dayton Gas Furnace Heater
Outdoor A/C unit fan
If the fan and compressor are shutting off. its possible its cycling on a low pressure switch. probably low on freon.
or you have a low ambient kit to keep pressures up during low outdoor temps while ac is running just the fan will shut off, however thats not a typical thing to have a residential system
Sep 20, 2009 | Heating & Cooling
The a/c unit cooling fan shuts down shortly after unit kicks on.
If a fan motor quits working during a cycle it usually means that the thermal protector is turning it off. If you had an amp meter on it, you would notice that it is exceeding the listing on the nameplate, Nine times out of ten this is irreversable, the motor needs to be changed. Sometimes if there are oil ports on the motor, you can add a few drops of zoom spout oil and that does the trick. But usually the motor is already damaged. Good luck.
Jul 11, 2009 | Carrier 38CKC036 Air Conditioner
Whirlpool dryer
If your dryer stops during its cycle, wait ten minutes and start dryer again. If dryer starts, then the motor was overheating.
Solution, Check for lint blockage around the motor and for possible overloading. If dryer repeatedly stops during its cycle, especially during consecutive loads, replace motor.
Good luck
Aug 10, 2008 | Whirlpool LER5636P Electric Dryer
Blower starts ans stops
May be a short in the wiring or a bad control board.
Jul 07, 2008 | Goodman CLQ36AR49 Air Conditioner
My machine runs for 5 seconds and stops for 15 minutes
The spinning motor are not turning / try it manually /if okey / the timer contactor is malfunction.
Jan 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
127 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
