Abit kn8 ultra mb no post one beep
Hello, i have an abit kn8 untra motherboard with an amd athelon 64x2 4800 processor. mob will not post and i hear one long beep but sometimes it seems like 2 beeps back to back. steps i have taken to eliminate some possibilities. test compute with new power supply. no go reset and cleared cmos like 10 times . no go the strange thing is that when i put it ram and turn it on it beeps once but when i add a video card no post no beeps and nothing on monitor. also a red and the green light stay on. i tired a different video card still same issue. i cant figure out if my cpu is toast my mob is toast or the agp . please help
  • parapner Jul 18, 2009
    my mb(abit kn8 ultra) does not have onboard video. i took all the memory sticks out and tried them one at a time, here is what happens , no matter if i put one stick or all 4 of them , it beeps one long beep then when i put the video card in and turn it back on with the ram installed i get no beeps at all and no post. one more thing is when all the memory sticks are out and there is no video card installed i get a continues short beep and if im not mistaking that means no ram.
  • 2,418 Answers
Trying your peripherals one at the time is the way to find your problem, Memory first - one beep is good, If your mb has onboard video use it first. if not check the settings in the BIOS may be a shared memory that is not set right. Make sure your memory is computable ck one stick at the time.
Posted on Jul 18, 2009
What is the fastest CPU I can run on an Abit KN8 SLI socket 939?
Your mobo rans in Athlon 64 socket 939 compatable processor. The fastest processor there is that you can install in this mobo is AMD Athlon64 4000+ Socket 939 Processor. =)
Apr 30, 2010 | Abit KN8 SLi Motherboard
Why does the keyboard not work when I start up motherboard. all devices and memory are found but then asks to press F1 or DEL but keyboards (usb and ps2) aren't working :( Motherboard is ABIT KN8 Ultra
Hello
Try this.
Unplug usb key board.start pc.plug usb keyboard in.should work.
Try reinstalling usb drivers or chipset drivers for motherboard if above does not work.
Feb 05, 2010 | Abit KN8 Ultra Motherboard
No sound drivers for MB kn8 ultra.
Go to the Abit website and download them.
Dec 27, 2009 | Abit KN8 Ultra Motherboard
GD8 motherboard
The GD8 mobo spec says that the bopard is only compatible with P4 and Celeron D processors so no you cant swap it! Generally the Athlon 1800+ is a better processor but it depends on the mobo, BIOS, RAM setup etc.
Sep 09, 2009 | Abit GD8 Motherboard
Can't install windows XP on my KN8 ultra
I believe you are using a sata drive not ide, correct? The problem is that vista has built in drivers to support your boards sata/raid controller, winxp does not. to work around this you need to go here -
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=KN8+Ultra&pSOCKET_TYPE=Socket%20939
Abit website. for your board - socket 939. KN8 ultra file called NVRaid Installation disk. click on picture, it will download the zip file. extract the files to an empty folder (create one). Then run RFDgen.exe program. It will create the floppy you will need. I hope you have a floppy drive, if not try a usb one. If it has a problem creating the floppy, copy the files in the folder floppydisk to your floppy. there is a readme.txt file in that folder as well that should help explain which option you should select when you install windows. So... once you have the floppy start your computer up with xp disk in and as the screen turns blue, you will see at the bottom of the screen a message - press F6 to select additional drivers. Do just that, a couple of times to be sure. then it changes to press F2, just sit back and wait. eventually it will come to a screen asking if you want to specify additional drivers. press S and the next screen will show you the drivers it found on the floppy. select the one for your configuration (can be changed in the bios). and then windows will load fine. this is necessary for all new systems with sata/raid installing xp. take care.
Feb 10, 2009 | Abit KN8 Ultra Motherboard
KN8-SLI newly installed, beeps but no start-up
Sounds like a bad or wrong stick of memory
Dec 21, 2008 | Abit KN8 SLi Motherboard
Abit KN8 ultra chipset coller
Try cleaning with compressed air.But i believe the bearings in rthe fan are bad..replace new.RichardM69
Nov 30, 2008 | Abit KN8 Motherboard
One long beep.
  1. Leave the memory slot closest to the processor empty and try booting again. Award bios 1 long beep is memory error as the first 64K of the ram stick closest to th processor is accessed first. since you have tried different ram in different locations, let's rule out the board.
  2. If that doesn't solve anything try a different power supply. Sometimes (Phoenix) gives a long beep when system board or power supply are bad.
  3. Now if nothing else has worked it is probably tour mother board.
May 16, 2008 | Abit KN8 Ultra Motherboard
Motherboard ABIT KN8
i dont know about the red light, but all main boards these days have a built in protection if the cpu fan quits. check the cpu fan connection, ensure that it and the heat sink are dust free. if still no go. update  your question with exact info..e.g. does absolutely nothing.. how many beeps you hear..how long b 4 it dies.. final note: be careful what you touch.. static can harm more that most think and the oil from touching can retain heat.
Oct 29, 2007 | Abit KN8 Ultra Motherboard
Manual
ABIT = http://www.abit.com.tw/
Sep 19, 2007 | Abit KN8 Ultra Motherboard
Computers & Internet Logo
344 people viewed this question
David Payne
David Payne
