Question about Kenmore Refrigerators
The water dispensor is dripping water, what do I need to do to fix this thanks
  • Kenmore Master
  • 4,655 Answers
On back of refrigerator there is a water control valve. One goes to ice maker and the other goes to the water dispenser. Unplug the one that goes to the dispenser and if the water continues to flow then you will need to replace the control valve. If you could find the model number near floor and behind the fresh food section door, I could tell you which part number you need, Let me know what you find, Thanks, Sea Breeze
Posted on Jul 18, 2009
Ge gss25pgmf
Before replacing water valve open open back panel disconnected water line of water dispensser and tell some 1 to press water actuator on dispensor and check water pressure from it. If its slow then it can be valve or it can be filter housing. Repalce both if confuse.
Mar 03, 2014 | General Refrigerators
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Hello, lost water in the house, now when came back on, water dispensor has a slow drip... the dispensor handle seems to be working fine... it dispenses water when pressed.. doesn't seem to stay...
If you take the bottom grill off the front of the appliance -1x Philips screw either side- under the freezer door you will see where the water pipe goes through the hinge. follow that pipe back towards the underneath of the machine and you should come across a push-fit connector.
The pipe leading through the freezer door from the connector, and blow down it, re-fit, press dispenser paddle to allow to flow. This stops the drip in 9/10 instances.
If not you may need to have someone check the water valve for slight blockage.
Jan 27, 2011 | Whirlpool Refrigerators
Water is dripping from water dispensor when off - how can i fix this?
You need to change your water valve. You've got a bad water valve.
Nov 29, 2010 | KitchenAid (KSRD22FKST) Side by Side...
FRS25R4A side by side. Water drips from the water
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Sep 07, 2009 | Frigidaire FRS26R4A Side by Side...
Water dripping from water dispensor -fridgidair sid by side
Hi, If the water is a constant drip, you will most likely need to change the water inlet valve. This valve will be complete with the icemaker valve also. Sounds like the plunger in the valve is starting to stick open.
I hope this helps. If I can acwer anymore questions, please ask.
Thanks
Vic
May 12, 2009 | Frigidaire FRS26R4A Side by Side...
Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Jan 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water Dispensor drips
You probably need a new water valve in the back of the fridge the valve is not shutting off completely  replacing valve will correct this problem
Nov 13, 2008 | GE GSS25JEMWW Side by Side
Water dipenser broke
drip tray pulls foward (might take some serious finger strength but itll pull foward, revealling 2 phillips screws that will release the dispensor facade. before attempting i would unplug the harness atop the freezer door, you dont want to short circuit boards behind dispensor.
Oct 19, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
67 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
