I need power supply for the spectra mini black and white tv model 5-bwr
  • 10,865 Answers
Take your tv to radio shack as they have a large assortment of power cords and adapters.
Posted on Jul 18, 2009
Spectra tv
The problem couild be power supply failure.
Aug 13, 2014 | Televison & Video
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Attach tv converter box
Everything is digital now. You will need a digital converter box. You will connect an antenna to it, and then connect the box to your tv. The box will come with it's own remote. Your tv will be set to channel 3 or 4 (depending on the converter box you get), and you will control the stations with the remote that came with the converter. You can get them at any electronics store.
Jan 09, 2014 | Jensen J53-BWR 5 in. Portable Television
I seem to have lost the instructions to my SUNPRO Super Tach ll and my SUNPRO Air Fuel Ratio guage. I am installing these items in a 1998 GMC Sonoma P/U.
I don't know which one you have
Sun Super Tach II
  • 3 3/8" Chrome Bezel / White Face - CP7903 ' Link
  • 2 5/8" Mini Chrome Bezel / White Face - CP7911 ' Link
  • 3 3/8" Chrome Bezel / Black Face - CP7901 ' Link
  • 2 5/8" Mini Black Bezel / White Face - CP7904 ' Link
  • 2 5/8" Mini Black Bezel / Black Face - CP7906 ' Link
  • 2 5/8" Mini Chrome Bezel / Black Face - CP7908 ' Link
StyleLine White Face Electrical Gauges
Electrical Air Fuel Ratio - CP8200 Link
Sport ST Electrical Gauges
Electrical Air/Fuel Ratio - CP7011 Link
Jun 17, 2011 | Televison & Video
I want to convert this power supply for use with a battery charger for model aircraft. I need to know the color codes for the wires and also the pinout and which wire is the power on.
Pin Name Color Description
1 3.3V Orange +3.3 VDC
2 3.3V Orange +3.3 VDC
3 COM Black Ground
4 5V Red +5 VDC
5 COM Black Ground
6 5V Red +5 VDC
7 COM Black Ground
8 PWR_OK Gray Power Ok (is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation)
9 5VSB Purple +5 VDC Standby Voltage (max 10mA)
10 12V Yellow +12 VDC
11 3.3V Orange +3.3 VDC
12 -12V Blue -12 VDC
13 COM Black Ground
14 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF.
15 COM Black Ground
16 COM Black Ground
17 COM Black Ground
18 -5V White -5 VDC
19 5V Red +5 VDC
20 5V Red +5 VDC
/PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
18 AWG is recommended for all wires except pin 11, which should be 22 AWG. For 300W configurations 16 AWG is recommended.
There are several ATX variants.
Hope this helps.
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me as well. Thank you.
Nov 26, 2010 | Compaq (243890-001) 250-Watt Power Supply
I need a wiring diagram and or a color code chart for the wires and plugs coming out of a "Power Tronic" switching power supply model SK-4145DE. 145 watt power supply. Thanks for your help.
Many power supplies have a chart on the side of the case.
Here are the wire colors for an ATX type supply:
RED +5, YELLOW +12, White -5, Blue -12, ORANGE +3.3,
PURPLE +5VSB, GREEN Power On, BLACK -Gnd (common).
Feb 14, 2010 | Power Tronic PowerTronic 145W Switching...
Tv spectra model ce-6443 can't unlock
Press the DISP button and hold for 5 sec.
This should unlock your Spectra TV.
Jul 19, 2009 | Spectra Logic 5-CTV 5 in. Television
Broken AC Adaptor
Check on Radio Shack maybe they got something usefull for your problem
Jun 03, 2009 | Spectra Logic 52-BW 5 in. Television
Digital signal
Most of the small (5") TV's do not receive digital, especially if they are more that a few years old.
Jul 15, 2008 | Spectra Logic 5-CTV 5 in. Television
Bose Radio doesn't turn on
The problem is a shorted NPN surface mount transistor on solderside of the PCB. It is located underneath of R402.
This transistor is used to switch power to the unit.
Hap Nguyen
nguyen_6@earthlink.net
Sep 26, 2007 | Bose Wave Radio
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
