Question about Magellan MAESTRO 3100 98083401 GPS Device
Gps will not turn on
I haven't used my magellan maestro 3100 for about a month and the battery was dead. Now I'm trying to turn it on. with it plugged into the cigarette lighter and its still not working and I reset it and still nothing. What do I do?
    President:
  • 1,111 Answers
Make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it them selves
you can email me through here or email to.... wmetz@comcast.net
Posted on Jul 18, 2009
Magellan maestro 3100 stuck at bootup screen
did that just happen all of a sudden or did you try and update the 3100 and it failed to boot after that...if you didnt try to update it...turn the 3100 on then use a paper clip to depress the reset on the left side bottom of the gps and let it restart.
if that fails, let me know and ill help you further
bill
Jul 15, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
My Magellan Maestro 31100 won't power on
You could have a defective power connection in your Magellan Maestro 3100 which will not allow you to charge the internal battery or power on your unit.
You may try to contact Magellangps.com or Autonav2000.com to see if they can provide you with repair service.
Might be cheaper to purhcase another Magellan Maestro than spend the money on repairs.
Good Luck
Apr 03, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Hi My Magellan Maestro powers up with the Magellan screen and the bar scrolls but thats all it does? Carl Lucas Aberdeen MD
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Aug 03, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Won't charge
Are you sure the plug in secure. If not, re-solder the plug. Take it apart and becareful around the plugs on the side
Mar 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My magellan maestro 3100 won't stay powered on
If the battery is fully charged then press the RESET button.
Jan 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 turns itself off
Try using the RESET button . Make sure the battery is holding its charge
Magellan maestro 3100 gps
Did you try to install the "Region Update 2.18" from magellangps.com ?
  • If you did, there is a solution posted for that.
  • If not, have you ever done a back-up onto an SD card?
  • If you did, copy USBTRANS folder from the backup to the Maestro SYS folder via a USB cable. Try it now.
  • If it still doesn't work, you will probably have to send it to Magellan for repair. Be prepared to wait a few months for it to be returned, and don't expect them to contact you with updates. I know that stinks, but it is the way it is.
Oct 07, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan GPS
Online at Magellan website you can update your magellan maestro 3100
Mar 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Will not come on.
GPS units should never be permanently left in vehicles. The vehicle interiors get way too cold or hot depending on the climate you live in and is very damaging.
Try taking it indoors and connect it via the supplied a/c wall charger and see if it turns on.
Jan 24, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3100 locks
You can try a hard reset. Hold in the reset button (left side of unit, use a pin or toothpick), while turning on the unit. If you don't get the blue Magellan screen, you'll have to try again. If you get a screen with a blue background and a menu, turn it off and try again.
So far, this has fixed:
1. unit won't go on
2. unit reboots when routing
3. unit turns off after a few seconds
At least, it's fixed it for me. No idea why this happens, but it's pretty damn annoying. Give it a try.
Dec 26, 2007 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan MAESTRO 3100 98083401 GPS Device Logo
323 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
