The photocopier was working but there was a white line on the paper.I remove the toner unit and clean, after assembling,when i photocopy the paper is blank.what can be the problem
SOURCE: canon ir 400 photocopier
What is the sub error code E805-" " -007 is is a blown fan and a blown fuse on the DC control. " " -002 could be a broken connection or pinched wire under the adf pillar on the right rear near the fixxing unit. If your have more info. on the code let us known..... Good luck
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
SOURCE: i have an error in canon photocopier IR 1210 E 245
errors are not described in service manual
trying to put out the power and put it back
if not resolve, you should reset the memory
stop the copier, get out the back cover and looking for jumper JP1, him out, wait 1 min, put in place jumper, start the device. I hope to help information
JP1: jumper plug for power used by battery to back up memory (control data; user data, service
mode data).
SOURCE: My ir canon photocopier shows
if you are changing the machine room from cold to warm, it can causes the error code E100, it's a condensation of the laser sensor. to solve this problem you need change the laser sensor PCB or the laser unit. or try to warm up the pcb sensor with a hot air. look at the picture to identify the laser sensor:
