Question about Labtec Axis 302 Consumer Headset
One side works and the other side does not work only once and a while.
Getting a new one.
Posted on Jul 19, 2009
1speaker will work i have cleaed according to instructions this just started
These types of failures are often component level failures. You could start with quick and easy stuff....but you'll need to open it up.
Once its open, start at the speakers and work your way back. First, check speaker connections (board side and speaker side) Then test the speaker https://www.youtube.com/watch?v=XpdKpnz8h64
If this is all good, then we are on to component level testing and inspection. Inspect the board for the obvious signs of failure. If this is good, go on to testing the output stage on the affected side. Use the good side as a reference. Work your way towards the front end (input stages) eliminating possibilities as you go.
Mar 01, 2016 | Audio Players & Recorders
Freezer is working but refrigerator is not :(
Hello, you need to find out if the evaporator fan in the freezer is working. or if the evaporator is all iced up. If the fan is not working you will need to replace it. If the coils are all iced up you have a defrost problem and that will need to be resolved. Once a evaporator is all iced over air can not pass through it and you will loose your cooling in the refrigerator first. Check the heater and the terminator to make sure they are good. You can use a hair dryer to clear the ice off the evaporator. Once you find the bad part replace it and the unit will function normally
Thanks
Jul 12, 2010 | Sub-Zero 695/O Side by Side Refrigerator
1998 chavy Cavalier-all windows but drivers side dead
you have to run a power wire to the motor in the door and press up on the window button it should go back up if not then you need to change the button hook up or the motor
Mar 17, 2010 | Chevrolet Cavalier Cars & Trucks
Turn signals not working 2002 buick century
one side or all?? do the hazard lights work/ blink? do all the other lights work??? if the other lights work, replace the hazard/turn signal module its up under the dash, tough to get to. I would have a repair shop replace it for you.
Sep 25, 2009 | 2002 Buick Century
Cleaned coke off keyboard, not disconnected, wiped over all keys on left side of keyboard. Now nothing works on keyboard at all. How to reset?
Try disconnecting it once and connecting again after restarting...the same thing happened once and disconnecting worked..otherwise just restart and checck the cable is connected properly..
May 27, 2009 | EzKey EZ-8000 Smart Office Keyboard
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
Water dispenser stopped working
Our fridge did this. Unplugged, plugged back in and it reset and is now working.
May 05, 2009 | Hotpoint HSS25GFP Side by Side...
Low Beams Don't Work!
There is more than one relay I know but make sure your bulbs are good I HAVE seen this happen more than once.. low beams can go at once.. and still have hi beams check this first please .. Jerry
Apr 22, 2009 | 2002 Chevrolet TrailBlazer
Icemaker not working
replace solid state or electronic board.
Jul 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Labtec Axis 302 Consumer Headset Logo
Top Labtec Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Labtec Radio Communication Expert? Answer questions, earn points and help others
