Question about Olevia LT42HVi 42 in. LCD Television
Olevia 242-T11 does not power up
A couple days ago, the TV would not turn on...the blue light would blink, but no olevia screen. I turned off the power switch for a while, and then turned it back on and was able to power up the TV, though there was a mild smell like some of the magic blue smoke got out :)
The symptoms are now the same, although I am not able to get the TV to turn on. I've also taken a look and find no obvious capacitors failing. The power supply fuse is opaque white, so I can't tell if maybe that blew -- won't have a meter to check it until tomorrow.
tvtek
  • 1284 Answers
SOURCE: olevia 242-T11 - I must have done something but
Reset to factory settings first...It will not hurt the TV at all..
Posted on Jul 23, 2009
  • 41 Answers
SOURCE: Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Posted on Dec 01, 2009
SOURCE: my Tv, Olevia LCD HD TV 242 FHD T11, will not turn on
Same thing Just happened to me ths AM. Acting Wierd then this morning fuzzy screen and poof won't come back on.
Comcast box was resetting at the exact same time and I found this online....
http://www.my3cents.com/showReview.cgi?id=18330&s=1188
Posted on Mar 09, 2010
SOURCE: olevia 242-t11 will not power up
replaced all caps on power supply FSP 271-4F02 module.Some caps were bulging @ top some were not but replaced them anyway.Total cost( 10 Electrolytic Caps) from Brantley Elec. fay NC was about $33.00.Took about an hour to remove and solder back.
Posted on Aug 07, 2010
budmrtn
  • 11361 Answers
SOURCE: Olevia 242-T11 We have no
It nay have dying power supply due to bad caps, please read my guide if you are going to DIY repair.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Apr 20, 2011
What is reset procedure for Olevia 242-t11
You have to enter its service mode option, and select the Factory Reset option there.
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Aug 03, 2014 | Olevia 42" 242-t11 1080i widescreen hdtv...
Oliva model 242-t11 won't turn on
Probable failure of the internal power supply
Mar 12, 2013 | Olevia LT42HVi 42 in. LCD Television
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
My Tv, Olevia LCD HD TV 242 FHD T11, will not turn on
Mar 06, 2010 | Televison & Video
Olevia 242-T11
Screen went black unpluged won't even turn on.
Dec 27, 2008 | Olevia LT42HVi 42 in. LCD Television
Firmware update Failed
I had the same problem with my olevia 242-T11. I flashed it with the wrong firmware and the TV would not even turn on. The blue LED light would still light up and my PC would still recognize a connection when i hooked it up to the USB cable connected to the TV.
I was fortunate to download the appropriate software. The software is called MTK_DownLoad1.exe. I know this is the correct software to use for Olevia 242-T11 and Olevia 237T. I do not know if this will work with other models.
Here is the link to the MTK_DownLoad1.exe
http://rapidshare.com/files/17475900...load1.zip.html
You will also need to install the USB to Serial driver before you are able to use the MTK Download Utility. The USB Driver is located at
http://rapidshare.com/files/17475900...river.zip.html
BE SURE ONLY TO UPDATE YOUR TV WITH THE CORRECT SOFTWARE OR YOU WILL BRICK IT. I was lucky enough to recover my TV and finally able to upgrade it to the correct firmware but my TV was non functional for about a week and this has been a huge headache and if i could go back in time i would definitely not do it so please ask yourself if its even worth it risking upgrading the firmware of a TV who parent company is reorganizing after declaring bankruptcy.
If you still want to do this, here are the firmwares for all the various Olevia models.
http://olevia.ftpaccess.cc/support/OLEVIA/
I hope this helps all the people who need to recover / unbrick their Olevia TV's. If the links are down or you need any help please ask for help in avsforums. My id is sammykismail on avsforums and i will try my best to help you.
Jun 23, 2008 | Olevia LT42HVi 42 in. LCD Television
Olevia LT42HVi 42 in. LCD Television Logo
749 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
