Question about Nokia N95 Cellular Phone
Hang no power - Nokia N95 Cellular Phone
Cq60 210us power
Hang? Can you stipulate what you mean by hang. It is not clear your intentions or how hang relates to the power? We need more information, please.
Jan 08, 2014 | Compaq Computers & Internet
My nokia 7210c hangs each time i power it on and any button don't respond when i press them
my nokia 7210c hangs each time i power it on and any button don't respond when i press them
Jul 12, 2011 | Nokia 7210 EarBud Hands Free Headset
My nokia 7210c doesnt power up. it just hang on nokia logo display.
Jun 18, 2011 | Nokia 7210
L7780 cannot get dial tone on 2-line outlet. Are there any work arounds to this problem?
There is a problem either with the Line Interface Unit (LIU, also known as the fax/phone line connector) or the fax hardware, because the unit is having problems sending or receiving faxes. The unit may hang on "Initializing." This document explains how to troubleshoot the LIU and fax hardware. SOLUTION: Please perform the following: Front panel hangs on "Initializing"
  1. Pull the power cord connector from the back of the base unit to recover from the error.
  2. Unplug the LIU from the back of the ADF. It is located on the left side (facing it), and is where you plug in the telephone lines.
  3. Plug the power cord back in, power it up, and see if it hangs without the LIU inserted.
  4. If it does not hang without the LIU inserted, power the unit down, plug the LIU back in, and power it back up. If it hangs, the LIU is faulty.
  5. If it does hang without the LIU attached, unplug the ADF from the base and see if it hangs. If it does, the base is faulty.
Testing the LIU The primary test for the LIU is whether or not you get a dial tone. Sometimes, you need to re-seat the phone line several times to get a good connection. If after trying the things below, there is still no dial tone, or initialization hangs, the LIU may need to be replaced.
  1. Verify that the phone line is connected directly from the wall jack to the plug in the LIU that says "To Wall Jack."
  2. Verify that the LIU is plugged securely into the product. If it is not, there will be a message at power-up saying the LIU is not connected. If it is, the date and time will display.
  3. If the LIU was re-seated, cycle the power on the unit. The unit should display the date and time.
  4. Unplug all other accessories, like a telephone answering machine or modem. If the LIU appears to work fine after unplugging them, these accessories may be interfering.
  5. Place a document in the Automatic Document Feeder (ADF). The display will flash "Document Loaded."
  6. Press Start Fax to verify there is a dial tone. If so, try sending a fax.
  7. If there is not a dial tone, unplug the product from the wall jack, and plug in a regular telephone to verify there is a dial tone at the wall jack.
  8. If there is no dial tone on the telephone, the wall jack or phone line may be faulty
Oct 26, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Hanging
power from adapter no capable to supply and need more wattage or change adapter with higher amperage. but still you need to change new battery.
Apr 02, 2010 | Toshiba Satellite A205-S4617 Notebook
Satellite A205 hang on AC power in Vista, Win7 but not XP?
Probably you will have to upgrade your drivers, specially power management.
Mar 12, 2010 | Toshiba Satellite A205-S4617 Notebook
Hanging problum D945 GCCR
hi im josh in cebu phils.may i help ypu? Friend if your pc hangs up. most problem of the pc hangs when the power supply has not enough current to support the motherboard.try not to use a lot of devices or replace your pwer supply with stronger one. or try to check also your memory if it is seated properly in the memory bank. good luck
Feb 20, 2009 | Intel D865GBF Motherboard
My laptop is hanging when i switch on. please give me ideas tha will reciver my laptop. laptop model: acer travelmate 290
OK people, I have this old acer 290 the battery refuses to charge so I use the power adapter but when I swith it on it may quickly flash on and then hang, turns completely off dead as a door nail. this happened all the time untill one day I left the battery out of it plugged the power adapter in and the problem dissapeared. I have not yet replaced the battery so dont know if a new battery will solve the problem when reinstalled?
Jan 25, 2009 | Acer TravelMate 290 Notebook
Camera got hanged
Unplug the battery and all power for about 10 or 20 minutes... reapply power and try it.
Robert
Aug 08, 2008 | Kodak V803 Digital Camera
Iphone hangs
press the home button and power button simultaneously fr say 10-15 seconds or maybe less.............it will reboot and itll help u a alot
so enjoy
Feb 28, 2008 | Apple iPhone Smartphone
Nokia N95 Cellular Phone Logo
43 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
