Question about Cell Phones
Blackberry storm 9530 displays sim card rejected
I got a unlock code which processed with no problem, but it says on the home screen sim card rejected can only make sos calls. why would this be happening. i dont think it is a unlocking problem because it said code accepted.. and all steps were done right..
Free MEP code for blackberry storm 9530
Are you asking a MEP code for unlocking your Blackberry 9530? If so you can get the accurate unlock code from www.unlocking4u.com/blackberry-9530/rs6wp9/ at affordable cost. Here are the steps for unlocking a Blackberry 9530:
- Switch ON your Blackberry 9530 phone with Not Accepted SIM Card.
2 - Click on Turn All Connections Off.
3 - Press Back button to go Back one Step.
4 - Go to Options.
5 - Select SIM Card.
6 - Press the Menu Key and select Show Keyboard.
7 - Tilt the phone in Horizontal Position so that the Keyboard is displayed in the Landscape Mode.
8 - Type MEPD (letters will not appear on-screen but a menu will pop up).
9 - Type MEP2 (user will be prompted to enter MEP code).
10 - Enter the unlock code.
11 - The Blackberry 9530 phone would then display the message 'Code Accepted' and unlocked successfully!
12 - Go back to the Home Screen. Press the Menu Button and click on Manage Connections.
13 - Click on Turn All Connections On.
14 - The phone will now reboot and 'Activation Required' will no longer be displayed
Sep 11, 2012 | RIM BlackBerry Storm 9530 Smartphone
Tip
How to unlock codes into a Blackberry 9530 Smartphone
How to Unlock a RIM BlackBerry Storm 9530 Smartphone.
1. Insert any SIM card and turn ON your Blackberry.
2. Turn OFF all the wireless connections.
3. Go Back One Step by Pressing the Back Key.
4. Go to Options
5. Select SIM card.
6. Press the Menu Key and select "Show Keyboard".
7. Tilt the phone in Horizontal Position so that the Keyboard is displayed in the Landscape Mode.
8. Type MEPD [you will not be able to see the typed info].
9. Then enter MEP2
10. Now your Blackberry will ask you to enter network MEP code
11. Enter the Unlock Code provided by us to you and Press the Enter Key on the Screen.
12. It will now say "Code Accepted'.
13. Congratulations! Your phone is now unlocked. Now your phone can be used with any GSM Network with SIM Card.
14. Go back to the Home Screen. Press the Menu Button and click on Manage Connections.
15. Turn all the Connections ON.The phone will now reboot and ''Activation Required'' will no longer be displayed.
on Feb 20, 2012 | RIM BlackBerry Storm 9530 Smartphone
I cannot make any outgoing calls or receive incoming calls on my blackberry storm 2 9530
Check your sim network is working or not,If you changed the Network sim card you will need to unlock it to make your Blackberry cell phone work with that sim card.You can get unlock code for your Blackberry by BLACKBERRY STORM 2 9530 UNLOCK CODE provider.
THANKS ! ! !
Oct 19, 2011 | RIM BlackBerry Storm 9530 Smartphone
I bought an unlocked verison blackberry storm 9530 but it does not recognize my sim card and it is forever in the sos mode. I'm using it in Trinidad and Tobago. I know for sure it is unlocked, I saw...
To determine your BlackBerry is "locked" or "unlocked" follow these process.
1. On your BlackBerry, go to Options, Advanced Options, Sim Card.
2. At that screen type MEPD (see note below) on your keyboard. A new menu will pop up.
If your BlackBerry has a Sure Type keyboard (71xx and 81xx devices) you will need to double-tap the P, so the actual keys entered become M E P P D.
3. Look for in the list.
4. If your device is "unlocked", it should say Disabled or Inactive. If it says Active, it's still locked to that carrier.
You can get your Blackberry storm 9530 Unlock Code here.
Oct 13, 2011 | RIM BlackBerry Storm 9530 Smartphone
Please need a code to unlock my blackberry storm 9530
Hey, Call your service provider to ask your Blackberry Storm 9530 Unlock Code. when you change your current network provider you must need to unlock your Blackberry first. after unlocking you can use your Blackberry to any network.but network provider take time to give your Imei Unlock Code.second option is, you can buy your Blackberry Storm 9530 Unlock Code from third party . this is safe way to Unlock your Blackberry . they will charge little amount but they give your Blackberry Imei unlock code immediately. i hope this information is help you.
Jul 29, 2011 | RIM Cell Phones
My Blackberry 9530 Storm not recognised the Sim card.. Please help me! on the screen is show SOS
Blackberry can be unlock eaisly with remote unlocking codes. you can get this Blackberry imei unlock code from your network provider or get from third party,
both are safe way to Unlock your BlackBerry Storm 9530. when you go to online you can find so many sites of Blackberry imei Unlock Code. they will charge little amount for your Blackberry Unlocking Codes. i hope this will help you:)
Best of Luck.
Jan 17, 2011 | RIM BlackBerry Storm 9530 Smartphone
I just installed pattern lock to my blackberry storm , but now i forgot the pattern. what should i do to unlock my phone ? please help me.. thank you
To Unlock BlackBerry Storm 9530 Smart phone you must need Unlock Code for BlackBerry Storm 9530 Smartphone.you can unlock your Blackberry bysimple entering unlock code through key pad, after unlock your Blackberry youcan use it with any GSM SIM card around the world. I know this trust fully Blackberryunlock code provider. I hope this Blackberry unlock code will very help fullfor you
Dec 05, 2010 | RIM BlackBerry Storm 9530 Smartphone
I'm trying to unlock my BB storm 9530,after I type "MEPPD" I enter "MEP2" or "MEPP2" but still I dont get any window to put the unlock code in,any ideas ?!
Before you start, you MUST have an Unauthorized Sim Card inserted. An unauthorized Sim Card is a Sim Card that is NOT belong to the provider of the phone. Example: If you have a Verizon phone, you need to insert a T-Mobile Sim Card inside the phone before turn it on. 1. Power on the phone.
2. Phone will said "MEP check failed. Do you want to enter MEP unlock code". Select Yes.
3. "Enter Network MEP code (# left)". Enter the unlock code.
4. Press Enter, you should see “Code Accepted”
5. You need to check Network Connection is set on GSM/UMTS. Menu>Manage Connection>Mobile Network Options and make sure it GSM/UMTS.
6. Once GSM/UMTS is selected. You can now ready to make phone call.
Notice: If the network not working after your phone is fully charged and unlocking process “Code Accepted”. You must change from Verizon CDMA network to GSM Global Network a few times, after change from Verizon CDMA to GSM Global 3 times is completed, leaves it on GSM Global Network. Now it should work. (Verizon 8830 World Edition DOES NOT work in USA)
Mar 29, 2010 | RIM BlackBerry Storm 9530 Smartphone
Cell Phones Logo
435 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
