Question about Garden
We are unable to remove bolt to change front tire?
We remove the nut from the bolt. E we not able to push bolt out. We were not able to ''beat it out with a hammer''? Changing front tire?
  • Richard63 May 11, 2010
    What is the brand and the model. Is the item Push or Self Propelled. Are the tires plastic or rubber, Solis or filled with air?
  • 130 Answers
Need more information.contact me at.
fr23487@hotmail.com. i will help you
Posted on Jul 18, 2009
Front axle
Remove the tire. remove the strut bolts. remove the axle nut. push the axle out of the hub(hammer out if necessary). Pull/push the hub away to get the axle completely out. Use a pry bar to get the axle out of the transmission. replace in reverse order. add fluid if necessary.
May 22, 2013 | 1993 Geo Storm
I was changing front passenger side tire when lug nuts snapped bolt off. How do I change lug bolts out to new one. Plan to change all for bolts and lug nuts for this tire.
take tire off, take brake caliper off, remove rotor, take nut and bearing off, then hammer out old studs and hammer in new ones. Tim
May 29, 2011 | 2003 Kia Spectra
How to change front brake pads on 2006 town and country
Loosen tire lug nuts. Jack up the car and remove lug nuts and tire. Remove two bolts holding the caliper in place. Remove the the two bolts holding pads in place. Hang caliper with a wire from wheel so brake line is not stressed. Mount new calipers in correctly and tigthen pad bolts. Put caliper on and tighten caliper bolts. Replace tire and lugs nuts. Jack car down and tigheten lug nuts.
Aug 17, 2010 | 2006 Chrysler Town & Country
Dodge daytona 89
just remove the caliper and bracket. then pull off rotor, if it dont just come loose its rusted on and you will need to beat it off with a hammer. one big hit is better [less damage] than several little hits. then just beat out broken stud. put new stud in and find some washers or nuts that go over the new stud so you can "****" in the new one with a lug nut.
Apr 10, 2010 | 1989 Dodge Daytona
How to replace rear sway bar links on a 1999 regal for knocking noise
First remove the tire on its corresponding side position of the side you are going to change.
the easiest way is to remove the pin and nut and that holds the spindle thing on top so you have some kind of slack to play with the sway bar link..then mark the thread of the all one how much deep is it where it connects to the sway bar so you put the one the same or you will need to take for aligment.
Next the remove the pin going through the nut opening...Then you will need to remove the nut that is facing down on the bolt of the sway bar link once the nut is out push the link bar up if it is to tight beat it with a hammer or a mallet from down the bolt to the top but before doing it make sure you got the right part you don't want to beat the all one up and have the wrong part..
Then just put new one in and the same way the old one was and everything should be good from there. Just put everything viceverse of how you started...
You should be good getting the spindle back in place may be hard if you can get someone to help you to push it is going to be lot more easier...'
Good luck. CR
Next just
Mar 15, 2010 | 1999 Buick Regal
Changeing front bearing hubs
remove the tire, then remove the brake caliper and its braket then slide rotor off. next is to remove the center axle nut, now look on the backside, you will see the bolts that hold bearing asm, in place remove bolts and hub comes off, you may have to beat hub with a hammer to break free, note if you have abs system disconnect connector before removing hub. reverse directions to install.
Jan 19, 2010 | 2003 Chevrolet Impala
Front wheel berings 2003 silverrado 1500 4 wheel drive describe procedure to change out
reomve tire securing the vehicle with tire hanging at it's lowest possition, remove the brake caliper & brake disc , remove nut lock on axle also axle nut , mark and remove strut bolts and push strut out remove ball joint lower bolt and use a fork ( tooling) seperate from hub slide hub off of axle , reverse steps to replace .
Aug 22, 2009 | 2003 Chevrolet Silverado 2500HD
Rear tire lug bolts
You have to remove the tire/wheel assy. remove the brake drum, you will see the spindle with the bolts there. punch out the broken bolts install new buy pushing thru the hole.Find some regular nuts that will fit over the stud, put your new nuts on and tighten up till flush in back.
Jun 07, 2009 | 2003 Chevrolet Cavalier
Unable to remove the tires.
Once All of the lug nuts are removed from the studs, if the vehicle is jacked up off of the ground, clearance under the tire, pull the tire off, it will be pretty heavy.
May 29, 2009 | 2005 Toyota Highlander
Replace rear struts 1996 buick regal
Here is a link describing your strut replacement. Autozone also has free tool rental for the strut spring compressor if you need it. Thank you, and don't forget to vote. http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152800681ba
Jan 29, 2009 | 1999 Buick Regal
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
