Question about Porter Cable 14.4V Hamm Drill Kit
My chuck would not rotate,(Porter cable 14.4V Hamm drill) but the motor would turn as normal as I pressed the switch. There was a grinding noise as the motor turned which I first heard when I attempted to hold the chuck while cinching up a drill bit. There was nearly no torque at all on the chuck, considerably less than what may be available on the '1' setting. I switched from high to low and all is now fine on both high and low. Torque settings now work Hammer now works. What happened? Should I be looking for a new drill, or maybe a new gearbox?
    President:
  • 1,273 Answers
It sounds like you were between gears. When you are in neither low or high, you are sort of in neutral. Normally it isn't a big deal. It happens to me occasionally, and I do what you did. You should be OK.
Posted on Jul 18, 2009
How do I change the bit on my porter-cable 18v drill? Where/how do I line up the black dial with the silver dial to release the bit??
I just looked at some illustrations on ebay of Porter-cable 18 volt drills and they appear to be fairly standard cordless drill/drivers fitted with fairly standard keyless chucks that you get hold of with both hands and twist in opposite directions like you are giving it a Chinese burn. The part of the chuck nearest the bit twists anti-clockwise to loosen.
If you have an SDS drill for heavier duty jobs the chuck is semi-automatic in the drill bit just needs pushing into the chuck and clicks into place but the outer part of the chuck is pulled back in order to release the bit.
May 07, 2017 | Drills
Drill press
pull it apart and have a look ?? if you know how pete
Oct 01, 2013 | Drills
How do I replace the chuck in my drill? It is making a grinding noise.
Chucks DON'T make grinding noises!!!!!
The grinding noise is probably coming from the REDUCTION GEARBOX which is located behind the chuck [the shaft upon which the chuck is mounted comes out of the gearbox].
There are usually four (4) screws mounting the gearbox housing/cover onto the motor/handle section of most drill/drivers.
The cause of most grinding nioses originating in the gearbox is lack of lubricating grease between moving parts.
Jun 02, 2013 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
Husband is out of town so how do you change the drill bit on the porter cable keyless chuck drill?
Switch drill to reverse, grab drill head tight, do not grab bit, pull trigger, chuck will open, switch to forward center new bit hold head tight pull trigger. Make sure bit stays in center, Let me know if this helps.
Aug 21, 2011 | Porter Cable Garden
While using my newly purchased drill model PLC1800 the chuck became disconnected from the motor, of course I don,t have the receipt. Have you heard of this problem before.
there should be a allen head screw that holds the chuck to the drill shaft should be a easy fix put loc-tite on screw threads before reattaching screw and chuck and tighten up screw
Jul 04, 2011 | Porter Cable PCL180DRK-2 Lithium Ion Drill...
How to remove a chuck on a porter cable 978 drill. Have take out lock screw and tried turning chuck counter clockwise with no luck.
go to the tip section and I put detailed instructions there, or under my profile it is there also. Let me know if still having problems
Aug 24, 2010 | Porter Cable Drills
Porter cable 3/8 chuck model 621. need to replace and cant find it
if you are talking about the J621 3/8 Professional drill the chuck kit number is 692074 and it lists for 43.30. You can but that from Dewaltservicenet.com or if you need more assistance let me know.
Mar 06, 2010 | Porter Cable Drills
Hilti te5 motor turning but not driving chuck
While the drill is running grab the chuck and turn it by hand. If you here a grinding noise that tells you the rotor gear is stripped.
Feb 20, 2010 | Hilti Drills
Seems like the clutch has gone in the drill. Can this be replaced? When I squeeze the trigger the motor turn and the drill spins but if I put any pressure on the chuck it stops spinning even though the...
Try rotating the driver adjustment to make sure it is on a definate number, not in between or put it all the way to the drill position. A little 3-in-one oil does wonders as dirt and dust will keep it from rotating and engaging easly. If this does not work and the clutch is stripped, cost of rebuilding it is not worth it, usually 70% to 80% of a new one and other parts on it will wear out and you will be fixing it again. Good Luck
Jul 03, 2009 | Porter Cable Cable 14.4 Volt Cordless...
Porter cable 884 cordless drill
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
Sep 27, 2008 | Porter Cable Cable 19.2 Volt Grip - To -...
Porter Cable 14.4V Hamm Drill Kit Logo
125 people viewed this question
Top Porter Cable Drills Experts
LINDEN DAVIES
Level 1 Expert
Tom Chichester
Steve P
Steve P
Are you a Porter Cable Drill Expert? Answer questions, earn points and help others
