SOURCE: my zannusi dryer is will not dry clothes on hot setting
thermostat in door part no 1258406014 should do the job colin
SOURCE: Dryer Heating But Not Drying!!!
if its not heating at all the thermal is the most likely culprit and it was the little plastic piece you seen now if you have a meter set it to continuity and pull one of the wires off the thermal limiter and check it if it reads open its bad same with the heating element let me know now if the heater and thermal limiter are good pull the blower motor vent and check it for blockage
SOURCE: Longer time to dry clothes
Remove the rear connecting vent and run a 45 minute timed dry load. If it works correctly repair the connecting vent and or blockage in the wall.
If this does not correct the problem make sure the glow bar is cycling at the gas valve and report back for further repair.
SOURCE: It takes my whirlpool dryer three or four cycles to dry clothes
Kenmore Dryers are almost all the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
It was helpful?
SOURCE: My general electric dryer DDE5300 is no longer
You Will have to use an ohm meter and the tub has to be taken out. You can on a GE open the door and push in on the door switch and starte it with the door open and look straight in and see the heater come on but if either the heat element of thermostat is out the element wont come on. If you live in ahouse with fuses instead of circuit breakes or a fuse box between the dryer and main circut box check the fuses an electric dryer will run on one fuse but not heat if this is the case switch the fuses and see if it runs if not one fuse is bad.
