Question about Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
I HAVE A SEAGATE EXTERNAL DOES THE SAME THING
Wont boot when connected to external seagate harddrive
  • Sphynkter
    Sphynkter May 11, 2010
    Will the drive not boot? or will your computer not boot? I'm guessing that your computer won't boot when the external is connected.
  • 416 Answers
Yes the PC will not boot when the external driver is connected, thats cause you dont have any boot files on the drive.
Posted on Jul 18, 2009
Using Seagate Goflex Hard-drive 750 GB, upgraded Windows 7 to Windows 10. get message Seagate harddrive not supported on Windows 10. Is there a solution to fix this? Russ
Will My Hard Drive Work With Windows 10? - PC Magazine
www.pcmag.com > ... > Windows 10
PC MagazineJul 29, 2015 - Some drive manufacturers have gone through the Windows 10certification process, ... Seagate products are NOT compatible with Windows 10.
Seagate GoFlex not compatible with Windows 10 - Microsoft Community
answers.microsoft.com/.../windows/.../windows_10-hardware/seagate...n...
Aug 4, 2015 - Since, the Seagate Dashboard is not compatible with Windows 10, let's try ... 10 with my Seagate FreeAgent Go Flex Home 1T external hard drive - model ... Windows 10 Backup Not recognizing Seagate Desk External Drive ...
Aug 18, 2015
Windows 10 Install- Now Seagate External USB 3TB HardDrive ...
Aug 13, 2015
Seagate 3TB external hard disk not working with Windows 8 ...
Jan 26, 2013
More results from answers.microsoft.com
Dec 16, 2015 | Seagate Computers & Internet
I burned out my external hard drives PCB board and I am unable to find a new one
The Printed Circuit Board ON THE Harddrive inside the Seagate FreeAgent, or the small PCB inside the Seagate FreeAgent's external enclosure? (Case)
If you are referring to the small PCB that the Harddrive connects to, and has the USB cable coming from it, just buy an external enclosure, and install the Harddrive into it.
http://www.youtube.com/watch?v=0HZ-wTdscgc
If your Seagate is like the one in the link above, it has a laptop size Harddrive in it, and it is a SATA unit.
2.5 inches across in width. (2 and a half inches)
This is an example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
IF you are referring to the PCB on the Harddrive itself, good luck.
One method would be to buy another harddrive like the one in the Seagate FreeAgent, and use it's PCB so that you can retrieve your information.
Then reinstall the PCB on the new harddrive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 17, 2011 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
Externalseagate 250go not open how to solve
If you cannot open or see the harddrive when you connect it to your computer after it is powered on then that is the external harddrive itself. First, check if the power connection is connected and the usb cord connect correctly. Then see if any lights come on on the external hard drive. If lights does come on and still nothing showing or coming on to the computer, then your harddrive is history. Seagate makes one of the worstest hardrive. You can google this up about seagate promblem and there are thousand out there who have this same promblem. I know this because I have the same promblem you have.
Jan 17, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I cannot boot my PC when the seagate hard drive is attached. I have to disconnect the external Seagate drive and then boot. Once booted I can physically plug in my seagate External Hard drive and it...
restart the system, while restarting , press delete/F8 to enter in BIOS menu, select boot priority and select the primary HDD as first boot device, deselct the "boot otehr device" option.
it should work fine.,
Cheers!
Sep 11, 2010 | Seagate Computers & Internet
My computer does not see my external hard dive
Go to this webpage (Seagate) http://www.seagate.com/www/en-us/support/downloads/ and choose from the SeaTools and FreeAgent Drivers that are appropriate for your OS and particular model. Formatting the harddrive should not have caused this problem of not being connected, but it is possible there was a piece of software that communicated with the computer that was removed via the format.
Apr 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Need Manual or Instructions for Seagate Portable Hard Drive
Your External Drive should be plug and play enable since it is a USB Drive.
Connect the appropriate cables to the External Drive and from the External Drive to the Computer while the computer is fully booted.
The driver for the Drive is loaded else you will be promted that the system have found a new device, if that is the case, put the CD-ROM that came drive and follow the instruction to complete the driver installation.
Open my computer icon on your desktop and you see the external drive.
Feb 01, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I cannot see my free agent external drive
u can see the news that the st drive has many bugs,and which cannot be detected by the pc is the most popular one,so u can update the firmware from seagate official and if still cannot repair,u can go back to me,honglake@gmail.com
Mar 15, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Seagate 500 Gig External Drive disappeared !
external harddrive turn them selves off after 5 minutes if it isn't being used.
Aug 06, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
171 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
