Question about Polaroid FLM-3734B 37 in. LCD HDTV
TV no longer comes on, blue light appears but no picture.
  • 3 Answers
I fixed my problem for $3.44 at Radio Shack.
This is a common problem with this model.. go to you tube and search for polaroid 37 lcd repair, there is a video showing which Capacitors to replace. there are two, i bought 2 1000uF 35 watt/volt capacitors. you have to take the back panel of the TV off, remove the power supply board, and de-solder the two CAPS. install the two new CAPS, re-solder them, put the TV back together and enjoy. Radio Shack part #'s i used 272-1032.
Posted on Aug 05, 2009
Also look for the caps to have a slight dome appearence to them is a sure sign that their blown
Edbull38
Posted on Aug 30, 2009
Led tv no picture
Sounds like fluorescent tube has gone, but you say this is LED? Newer tvs are LED. What you have, may be LCD, in which fluorescent tubes were used. You have no recourse.
Feb 12, 2014 | Televison & Video
Samsung led tv no picture
What did you do when you say you cleaned the screen? If you shine a flashlight on the screen can you see some very dim picture? If the back light is out. This will require replacing the power board.
Jan 06, 2014 | Televison & Video
Tv will not turn on i push power on button and blue lights click on an tv acts like it will come on but then tv shuts off and no picture appears
The blue light merely indicates power is getting to the TV. When you press the power on button, the defective power supply shuts the TV down immediately
Jan 06, 2013 | JVC LT42P789 42 in. LCD TV
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
No picture
If your TV is less then a year old, still cover under manufacturers warranty, if not the solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 28, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Blue screen
Check the CRT.and then check if there is a loose solder on the whole board and also check the H-out..change the CRT socket which is Color White Connected to the Tube.
Nov 12, 2008 | Samsung TX-R2735 27" TV
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Polaroid FLM-3734B 37 in. LCD HDTV Logo
557 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
