Its very rare a mac has sound problems. Some earphones consume batteries, does yours have batteries in it? and is it powered on while connecting? With the earphones connected, check system volume and increase the sound while playing music. If there is sound coming from the mac itself then there maybe an issue with the AUX connection. Possible dust blocking the port. Clean it and try again. If there is no sound coming from the mac itself while the earphones are connected, then the AUX port is connected to the earphones and is in good working condition. Increase the volume on both devices, the mac and the earphones, if it has this feature. If there is still no sound, there may be a problem with the earphones itself. Possibly bad wires already, connect the earphones to other devices and listen for sound. If still no sound, replace earphones.
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
You will need professional help on this, the laptop must be dismantled down to the motherboard level to access the problem. The earphone jack may have to be replaced and requires a high degree of solder skills to remedy the situation.
My dear friend, the problem is simply that the earphone of the bad/ damaged that is why you cannot hear anything on the phone. As long as your caller can hear you but you cannot hear them, then it is confirmed, because, the speaker is on a different side of where the earphone of the phone is.
The solution is just for you to have the earphone of the phone replaced.
But before replacing the earphone of the phone, you can use a bluetooth hands-free temporarily or an external earpiece that you can connect to the phone and be using on the phone temporarily before replacing the earphone of the phone.
Using a bluetooth hands-free or external earpiece is quite cheap and is of easy access.
The problem is obviously as a result of the fact there is a loop in the wire as a result of a breakage in the wire hence the right earphone is not working.
The solution is to replace the wire that connects to the right earphone,or better still get another earphone.
The headphone jack on your PSP has died, this is actually very common, and there's not much you can do about it other then contacting Playstation and asking for a repair order.
the connector may have come loose from the player board, you could try opening it and replacing/resoldering the port, but it would be best if you just sent it back for repair.
hi the problem will be with the earphones after a bit of use the wires inside the plastic casing covering the wires where they plug into the mp4 these wires fray and eventually short out it is best to replace the earphones as soon as possible as shorting out will eventually cause the mp4 to overheat and short out. If you have replaced the earphones and are still getting the same problem then it will be the solder points on the jack plug that you plug the earphones into the solder eventually will work lose causing bad connection but first repalce earphones then if you still have the problem but you probanly wont as the solder failing isnt a known problem with this product then you will need to take the cases off and get to the board where the earphone socket is soldered onto the board then you need to resolder the solder joint that connect it to the board. But first repalce earphone with new ones as using someone elses or old ones might have same problem let me know if you need further assistance
