My dryer does not go into the cool down cycle. It continues to dry at the hot temp throughout the cycle setting. If I don't catch it in time, the thermal fuse blows. Also, it shuts off, but the timer continues to advance through the next cycle on the dial. It is my understanding that the timer controls the cool down, is that correct? Any assistance would be greatly appreciated. Thank you.
  • zinnel Jul 18, 2009
    It is an electric whirlpool dryer. Model # LER6634DQ0. Let me add just a bit about how this came up. The dryer had accidently gotten started with nothing in it. My husband was positive the issue was the timer which he replaced. I stared researching on the internet and had him check the thermal fuse, which we had to replace. After replacing the thermal fuse, the dryer worked, but doesn't cool down. I will have him check out your recommendations. Thank you very much.
    President:
  • 1,136 Answers
Hi, I need to ask a couple of questions to try and narrow this down. Is this dryer electric or gas? Can you get me the make/model # so I can see the exact dryer you have please?
It is possible the operating thermostat is not sensoring properly. Another option is, (if this is electric heat) that the element has broke and shorting out against the casing.
Please let me know.
Thanks
Vic
Posted on Jul 18, 2009
  • 1 more comment
  • Victor
    Victor Jul 18, 2009
    Thank you. Have your husband check the wires to the timer to be sure nothing was crossed. He can remove the heating element and see if it has broken.
    Make sure all the 4" venting to the outside is clean. While he has the back off, remove the 2 screws under the lint screen and the 4 screws holding the lint screen duct to the blower in the back and see if there is any lint plugging the lint screen duct.
    These are all options to consider and narrowing this down.
    Please let me know.
    Thanks
    Vic
  • Victor
    Victor Jul 18, 2009
    Hi, I am curious if any of my suggestions helped you at all or if there anything more I can assist you with?
    Please let me know.
    Thanks
    Vic
  • Victor
    Victor Jul 21, 2009
    Hi. Was anything I mentioned helpful? Please let me know if there is anything else I can help you with.
    Thanks
    VIc
I have kenmore he4. My cloathes dont dry completley. My flame ignites for 20 seconds then goes out. Then this behavior continues about every 5 minutes throughout the cycle. Ad the cycle continues the...
I still say ur safety gas valve and coils are bad SORRY NOT ABLE TO HELP MORE WHEN U CHECK the ceramic igniter it could test good meter wise but yet be bad mechanically which would also do what ur experiencing if it was going bad
Mar 29, 2015 | Kenmore Dryers
Kenmore Elite HE4 Gas Dryer Shuts off prematurely in the Auto Dry cycle and the Timed dry cycle
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Jul 19, 2014 | Kenmore Dryers
I want to know how hot my dryer gets. I do not have temp. controls on my model
Good Morning Tabitha,
I see that you are looking to see how hot your Frigidaire dryer, model# FER311FS, actually gets, due to you not having temperature controls on your particular model. Being that you have just the timed dry cycle, it provides up to 100 minutes of drying time at high heat for regular and permanent press items. When drying permanent press items, turn the cycle selector to 40-50 minutes. This is the average time needed to dry most loads of permanent press items. The load tumbles without heat during the last 10 minutes of the Timed Dry cycle. Use this setting to refresh clothing, pillows or blankets or to dust draperies. Heat-sensitive items such as plastics, foam rubber or similarly textured rubber-like materials or items containing feathers or down should be dried only with this setting. Hope this is helpful.
-Best Regards-
Mar 17, 2014 | Frigidaire FER311FS Electric Dryer
Drier not hot enough when i set temperature to high position
Replace the high limit thermostat located on the top of the heating element housing. Here is the part to order.
Nov 18, 2012 | Frigidaire GLER104FSS Gallery Series 27...
Dryer model Roper RED4340SQ1 rmy heater don't stay hot all the time during a drying cycle is it normal or i need to change it
You may want to do a thorough tuneup on your dryer. I worked on a couple and wrote a pictorial on it. ROPER DRYER TUNE-UP
My Home movie of a Roper dryer with a heat problem:
Sep 06, 2012 | Roper Dryers
How do i do drying only
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry button. • For most even drying , make sure all articles in the clothes load are similar in material and thickness. • Do not overload dryer by stuffing too many articles into drum. Items must be able to tumble freely • If you open door and remove load before dryer has finished its cycle, remember to press the Start/Pause button. • By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less" • Your dryer can handle a load of up to 9 lbs. (4 kg) dry weight of articles. • When drying cycle is completed, [Cd] (Cool Down) is displayed on the Multi display. • Cool Down is set automatically when the drying cycle is complete. • If clothes are not removed promptly when the drying cycle ends, wrinkles can form. • The Cool Down feature periodically tumbles, rearranges and fluffs the load to avoid wrinkles for up to 4 hours. • The message [Cd] will continue to display until the clothes are removed or the Start/Pause button is pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment Thank You Joe
Sep 06, 2011 | LG WM3431 Front Load Washer / Dryer
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Roper electric dryer. Clothes not drying. Temp ok/timer not?
I would supect a faulty high limit thermostat. This small round device is mounted to a metal plate and attached to the internal ductwork. It can be tested using a multimeter or ohmmeter. Test for continuity. It should have none. Hope this helped and best wishes.
Aug 11, 2009 | Dryers
Dryer too hot...no cool down
no the thermal fuse has nothing to do with that,although it will open again if too hot and that may be why it opened in the first place.most high heat ,long dry times are the house ducting.try this experiment.remove your dryer from the house ducting and dry a load[it wont hurt a thing]if not as hot,then get that ducting cleaned.if still hot then make sure the inner dryer air ways are clean.your blower is spinning fine[not broken on the shaft]and also check with ohm meter,or visually that your heating element is not shorted to ground[then it by passes the cycling thermostat.if all those things good and still getting high heat i may replace the cycling thermo.but as a repairman i did not have to do that very often.most of the time it was the other possibles. i hope this helps abit God bless ,tom
Feb 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
