Question about HP Pavilion Media Center TV m7360n (EL409AA) PC Desktop
Video is scrambled
When booting the pc it shows vertical lines across the screen (even the HP invent page has it:-( ). Tried different monitors, same result.
Did a full restore and that didn't even fix it.
running winXp-sp2.
WindowXP startup screens shows up but than nothing after that.
which component do you think needs replacement?
  • rsaltzhe Nov 19, 2007
    tried a different monitor, same results, so don't think its the pin. Is there an easy way to determine if the videocard is broken?
    I shook the card in the PC slot and that seems to fix it. seems the card got dislodged a little.
  • 317 Answers
It's probably something to do with your video card. The card could need replaced or there could be a bent pin in the plug. Check for the bent pins first.
Posted on Nov 19, 2007
HP Dv7-1130us LCD screen displaying vertical blue line
the actuall screen LCD is bad.
in most cases.
supper common failure.. 2008 PC.
see page 31 , part 5 here. bingo, change that out.
there are 2 types used, only your full PC part number on
the service tag show this, post that and we go to the HP parts surfer and look it up.
Sep 28, 2017 | HP Pavilion dv7-1130us laptop
Dell HP Pavilion screen scrambled
Either your monitor died or your video card/chip died. Test your tower with a different monitor or test your monitor with a different tower.
Aug 25, 2012 | HEWLETT-PACKARD Hewlett Packard HP...
Intermittent problem a vertical red band (6-inch wide) appears on the monitor can last from minutes to hours before disappearing; then will reappear hours, days, or even weeks later.
Welcome to FixYa,
One of the top reasons for causing these "lines" running across the screen are :
  1. Corrupted video driver
  2. Changes in hardware configuration (display)
  3. Monitor issue (hardware)
In order to determine if it's hardware/software issue, all you need to do is to boot to BIOS and check if the problem replicates. Depending on system, you can go to the BIOS screen by tapping "F2" or "DEL" key repeatedly as soon as you turn on the computer until you see a different screen.
If the problem is present while in BIOS, then definitely the monitor needs to be repaired by an authorized repair center. Otherwise, video driver update or Operating system re-install can resolve this problem.
I certainly hope this helps,
Thank you for using FixYa.
Mar 04, 2011 | HP Vs17 17" LCD Flat Panel Monitor
Video on my HP Pavilion a1540n is broken
Yes you put in the video card and the default is lowest resolution and is usable without a driver, install driver then reboot and you have your new video card to set up the way you want.
May 15, 2010 | HP Pavilion a1540n PC Desktop
First one and now 2 vertical lines on my HP f2105 monitor. Would this be the actual screen or a component that drives it? Thanks
Move the mouse cursor across the lines then check if it shows up fine. If it shows up fine, the problem is in the video card itself, not the monitor. It can be caused by VRAM or GPU overheating. Clean the video card thoroughly. Using a compressed air is a good alternative.
Oct 18, 2009 | HP f2105 21" LCD Monitor
IBM A31 2652 Video garbled video at boot
This is very possibly a hardware problem, namely a crack in the motherboard. Sorry, no easy or cheap fix for it if that's the case.
Feb 18, 2009 | IBM ThinkPad T42 Notebook
update monitor driver
your screen may be going
how old is the system
Jan 26, 2009 | IBM ThinkPad A31 Notebook
IBM Laptop A31 2652 Garbled video even at initial boot screen
Connect an external monitor to the laptop, power up the monitor first and then bootup the laptop. The Windows image will automatically divert to the external monitor.
If the images is OK then the video card is OK.
From the description of the fault, it indicates that the fault could be a faulty video cable or video connector. Try reseating the video cable/connector on the motherboard.
Get back to me if you still have problems together with any error messages etc.
Jan 25, 2009 | HP Compaq Presario F750US
HP Pavilion Media Center TV m7360n (EL409AA) PC Desktop Logo
137 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
