Question about Maytag MER5775Q Electric Kitchen Range
Electronic display is displaying F9 - Maytag MER5775Q Electric Kitchen Range
    President:
  • 1,723 Answers
This is the code for F 9
F9 Door latch Check door latch components.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 18, 2009
Oven does not work displaying a F9 on the display
F9 indicates a fault with the door lock (for self-cleaning mode). Could be the lock itself, the control board, or wiring in between.
If you can use an ohmmeter, this link has some pretty good instructions for troubleshooting a GE oven with F9 error. It does require cutting power at the breaker box and some specialized tools, plus the repairs are somewhat complicated.
How to Fix F9 on GE Oven Hunker
Oct 21, 2017 | Kitchen Ranges
Lg oven not heating after self cleaning. code f9
F9 stands for oven no heating. It will be displayed if oven temperature readout when oven temperature doesn't exceed 150F/66C in less than 5 minutes from set time. I would say you may have a heating element malfunction..
Oct 23, 2016 | LG Kitchen Ranges
F9 code with a spanner underneath
Its a most common problem in this kind of model. The reason for F9 display in your washer is that due to a electronic malfunction that occurred in your unit. You cant replace any of the faulty part in your washer and its very difficult to identify the faulty area in your unit. So if you think you can do it by your own then the answer is "NO".Best way to fix your problem is that call your authorized service centre and they will fix your problem for sure.
Thank you !!
Jun 18, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
I have the code F9 what can I do
F9 usually means that the oven lock is partially engaged after cleaning. Normally, the door unlocks automatically after the cleaning cycle is through. Unplug or turn the oven off a the breaker switch. Leave it off for a moment. When you turn it back on, the error should resolve. As a caution, unlock problems are notorious after cleaning, a long with fried electronic controls. Clean sparingly. Thanks for using fixya.
May 08, 2010 | Amana ACF422 Electric Kitchen Range
F9 beeping
Its a most common problem in this kind of model. The reason for F9 display in your washer is that due to a electronic malfunction that occured in your unit. You cant replace any of the faulty part in your washer and its very difficult to identify the faulty area in your unit. So if you think you can do it by your own then the answer is "NO"..
Best way to fix your problem is that call your authorized service centre and they will fix your problem for sure..
Apr 04, 2010 | Fisher and Paykel 24 in. DD603H I Built-in...
Oven is locked and F9 is being displayed, what do I do?
Hi
Thanks for using FixYa.F9 is a door latch error, you’ll need to check the door latch. This is a Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch. You’ll need to check wiring and replace the door latch assembly if required.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 14, 2010 | Maytag Ovens
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
MICROWAVE WILL NOT HEAT. F9 APPEARS IN THE DISPLAY WINDOW
F9 indicates a problem with the door latch.  There is a safety switch that will not allow the microwave to operate if it detects the door is not closed properly.  Even though physically it may seem the door is shut, the safety switch is not relaying the message to the onboard computer.  You need another door latch switch.
Mar 10, 2009 | Kenmore 63663 Microwave Oven
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
F9 Display in Model MGR5770ADB Gas cooking range
f-9 means you either have a bad door latch hinse the light staying on, or the ERC which is the oven control has a stuck relay and youd have to replace the ERC to fix it.
Nov 26, 2007 | Kitchen Ranges
Maytag MER5775Q Electric Kitchen Range Logo
109 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
