Question about White Mountain F69206X 6 Quart Ice Cream Maker
My white mountain ice cream maker spins the whole cannister
My white mountain ice cream maker spins the whole metal canister. Is that normal? I thought just the inside mixer would turn.
5 Suggested Answers
SOURCE: Motor does not stop
If you check the instructions that come with the white mountain ice cream maker, they talk about the problem of the custard not freezing in the center. It is because you have your salt to ice ratio out of whack. Too much salt causes a situation similar to your description. You want to shoot for 12 degrees and if you add too much salt, it goes lower than that.
There are copies of the original instructions online (usually in a pdf file format) that are worth looking for and reading. Rule of thumb 1 to 5 ratio of salt to ice.
Posted on May 27, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: I have recently obtained a white mountain 4 quart
This may what you're looking for. (If it helps, invite me over to test out the results
Posted on Mar 31, 2010
SOURCE: Why won't the freezer freeze the ice cream? It
According to White Mountain, this happens because the ice brine gets too cold. The procedure they recommend is as follows:
After you put your cream can in the tub and attach your crank or motor, fill the tub with ice and run for two minutes to cool the cream can. Then, put two cups of rock salt on top of the ice and let it continue to crank. After the ice level has dropped 2-3 inches, put more ice on top and another two cups of rock salt and let it continue to crank until the ice cream is done.
Posted on Nov 21, 2010
SOURCE: White mountain freezing problem
NO SOLUTION but I have this same problem with my machine.
Posted on Feb 26, 2011
Motor will run but the buckle will stop turning when you add ice
That usually means that the gears in the unit need to be repaired. This might be able to help.
White Mountain Ice Cream Freezer Motor Repair
Sep 09, 2013 | White Mountain F69206X 6 Quart Ice Cream...
White Mountain 69204 ice cream motor gear slips
Sometimes the gears in the unit become worn and have to be replaced. This might help.
Sep 04, 2013 | White Mountain F69206X 6 Quart Ice Cream...
Why won't the freezer freeze the ice cream? It freezes around the outside of the cannister only.
Sep 24, 2010 | White Mountain F69206X 6 Quart Ice Cream...
My ice cream churn just spins the lid and does not turn the canister. The only thing that is different is that the lid does not seem to come to a halt when I place it on the cannister and turn it. There...
maybe you have a super strong husband who tried a little too hard to loosen the lid once and now it won't seal or catch. if he is equally smart as strong maybe he could get some sort of gasket type idea going with the lid or something else ingenious. but it sounds like that might not be up his ally as much as throwing it across the room. could you try buying a new lid since everything else is working well? maybe the lord is telling you to get more iron in your diet and less ice cream? ha!
julie j your beloved daughter
Aug 18, 2010 | Rival F69206 6 Quart Ice Cream Maker
Metal shavings in ice cream
Sounds like the center rest in the bucket might be worn or gone and letting the cannister ride too low in the bucket.
May 09, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
The motor runs but it will not turn the dasher.
dasher is supposed to be statioary so it can scrape off the frozen mix as the cannister turns. That is the secret to mixing the frozen mix into the unfrozen part to thicken the mix in the can. It pushes the frozen part toward the middle as it scrapes it.
Mar 21, 2010 | White Mountain F69206X 6 Quart Ice Cream...
Need replacement can for Sterling Catalog No. 165A (Is Rival 8550x Equivalent?)
Richmond Cedarworks has folded. Rival/White Mountain do not have parts for the replacement of your canisters. Richmond has went under for bankrupcy or were bought out by some private sector. The parts offered by Rival/White Mountain are different sized for all of the Richmond products. As there are no parts available, anyone looking for parts should be directed to either commercial supply stores or stores that repair/rebuild old kitchen equipment.
Sep 09, 2008 | Rival 8550-X 5 Quart Ice Cream Maker
Ultrex ice cream machine
Put the metal canister into the freezer overnight. This replaces the ice and salt in the old bucket style ice makers. After the canister is frozen use any ice cream, yogurt, or sherbet reciepe. Ben and Jerry's have a good website for receipes.
Sep 01, 2008 | Ultrex Double Canister 2 Quart Ice Cream...
White Mountain F69206X 6 Quart Ice Cream Maker Logo
105 people viewed this question
Top White Mountain Ice Cream Makers Experts
Andrew Taylor
Andrew Taylor
Are you a White Mountain Ice Cream Maker Expert? Answer questions, earn points and help others
