I can't run any regular cycles on the washing machine. Help!
In top loading washing machines, the agitator is responsible for moving the clothes through the water and detergent and is driven by the output shaft of the transmission. The output shaft is normally splined and the center of the plastic agitator will have a matching spline to ensure a tight fit. Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
