Question about LG VOYAGER VX10000 Cellular Phone
I just flashed my verizon lg voyager to cricket and for some reason i can't get music, web or picture messaging! Can anybody help me out?
Have a lg vx1000s that was verizon flashed to cricket. It has been hooked up through cricket previously, however i spent 12 hours trying to hook it up yesterday, finally got far enough that they took my cc...
Try *22804 it seems to work for verizon phones that are failing on *288 more often than not.
However if your phone was fully flashed you may need to have it reprogrammed since these phones need to be programmed to your number, without this most likely you will only get talk and text.
Dec 26, 2010 | LG VOYAGER VX10000 Cellular Phone
Moto q
I believe the Moto Q can support this so the basic flash you received only hacks the SPC, changes it to null value and writes the PRL (preferred roaming list) for Cricket and it's partner carrier's towers. Then, assuming it has not been reported lost or stolen, they will add your ESN (electronic serial number) or IMEI (international mobile equipment ID) so you can make and recieve calls. This does not enable picture messaging or internet. This is a separate procedure using computer software and there are several things which need to be changed in the firmware like your MID (mobile identification number) web addresses, protocols, and passwords for Cricket mobile service. You will need to take it to the person who flashed your Verizon and ask for the full flash so you can get the internet. I hope this helps. If you already paid for the full flash ask them to redo it and test it before you leave the store.
Jul 13, 2009 | LG CHOCOLATE VX8500 Cellular Phone
My phone won't send or recieve pictures anymore
the best solution is to just take it back to the store and have them replace it.
Jun 01, 2009 | LG VOYAGER VX10000 Cellular Phone
My LG Voyager has been flashed to Cricket, but the MP3 player is saying , I have no application in my music and music area .
all you have to do is have your voyager reflashed back to the v05 firmware and then have them or you to flash it back 1 firmware at a time v07, v09, and v11 and this time donot mess with brew settings and this will fix the problem. by the way important note: YOU WILL NEED TO CHANGE ALL BREW SETTINGS BACK TO VERIZONS' BREW SETTINGS FIRST OR THIS WILL NOT WORK!! i have a voyager and i made the same mistake but i fixed it if u need help email me at badboy038128@yahoo.com
Apr 13, 2009 | LG VOYAGER VX10000 Cellular Phone
Verizons LG Voyager fully flashed to cricket but internet not wor
If a dealer is knowedgeable enough to claim that an LG Voyager is fully flashed, then he should know that he must activate it on its intended phone #, at the time it is flashed. Otherwise, the web will not work. This is known and common problem with the LG Voyager, and if you are able to fully flash this phone, you're aware of this problem and know how to deal with it.
Sound like this dealer did not do the flashing themselves, and were not properly trained on how to activate and refresh wap settings on a Voyager at the time of sale.
The LG Voyager must already be activated on its intended phone #, at the time the phone is flashed. This is unique to the Voyager. None of the other verizon LG phones have this requirement.
The reason is because the simple act of dialing *228, or manually programming the phone#, erases the WAP settings on this particular LG phone. Specifically, it is the WAP Gateway that is erased, and this can only be fixed by somebody who knows how to flash this phone.
This is the only verizon LG phone that will automatically erase its WAP Gateway when the phone # is programmed into it, by dialing *228.
If your Voyager is working, DO NOT DIAL *228, EVER, Keep in mind, if you call cricket for any type of billing/tech support on your account, they will tell you that you must dial *228. DO NOT DIAL *228, if you have an LG Voyager. *228 is similar to restarting your computer. It's good advice, but is usually not required.
If you are going to pay somebody to fully-flash your phone, that person should offer, even require, that they transfer service to your phone for you, at the time it is flashed. The only way to know for sure your phone was properly flashed, is to test out the web and picture messaging features, when your phone is done being flashed. I *always* test out the web browser, and incoming/outgoing picture messaging, before I consider a customer's phone to be ready.
There's is no 24hr waiting period for web/picture messaging. Basically, if it works for voice/text, there is nothing to keep web/pix from working immediately. A dealer or experiened flasher has the tools/resources to make sure the customer's account has the proper features for web/pix to work.
My last piece of advice, is that you do not have to be paying for web, in order to use the web browser on a fully-flashed cricket phone. That is right, cricket offers free web-portal access to Cricket's homepage, which doesn't include much, but does give me a page or two to load, to make sure the phone is working correctly. If you have picture messaging, you should be able to visit this page, even if you don't have web on your account: http://wap.cricket.motricity.com, and http://search.wap.mycricket.com.
There is an easy way to test if your Voyager has simply erased its wap gateway. If you can send and receive picture messages, but just cannot use the browser, then your phone is flashed properly, but needs to have its wap gateway settings refreshed. You can verify this by visiting http://www.accuweather.com, because if picture messaging works, accuweather.com will load in the browser as well. This is because accuweather.com is unique, it's the *only* website that will work on a cricket phone, without going through Cricket's wap gateway.
Well, hope this help and is not too much information. I will say, though, everything I've written is 100% accurate. I have been doing "full flashes" on Cricket phones for almost 3 years, before most people even knew you could do basic flashes. The best resource on the internet for learning about the capabilities of flashed Cricket phones is at howardforums.com, in the Cricket subforum, located here: http://www.howardforums.com/forumdisplay.php?f=336
Jay
Denver, CO
aka beezlewaxin
PS - I cannot wait for the day when my answer is proven wrong, which can only happen when somebody figures out how to flash the Voyager so that *228 is safe, and no longer erases the wap gateway. Tougher problems have been solved, maybe someday this one will be solved too. Until that happens, DO NOT DIAL *228 IF YOUR VOYAGER IS WORKING!!! can't say that enough....
Mar 28, 2009 | LG VOYAGER VX10000 Cellular Phone
My lg vx8700 verizon cdma was flashed to cricket but no wap/mms
i had the same problem and have the same phone which has been flashed 2 ckicket. but i can get picture messages. on your phone go to messaging and then 8 to get to the internet browser. then when the error message pops up hit 282 and it will restart the browser to allow u to get to the internet.
Dec 30, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Can't send picture messages
Are you the account holder? It's possible whoever set up the account blocked picture messages from being sent. If you log in to your account, you can change these features, or if you aren't the account holder, talk to that person. Picture messages cost more than regular text messages.
Apr 18, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Lg EnV VX9900
You might not be able to use that becasue thats a verizon feature and they have there network info bassically permenently installed in the hardware. If you open the flip phone, hit menu, and hit " 0 " it will give you a service menue, password is all 0's
Dont mess around in there, you could mess up the phone, but if you look at the setting, somewhere in there it will show you that verizon has there info in there even though cricket flashed it, you cant change it. At least no way that i have found.
Jan 08, 2008 | LG enV VX9900 Cellular Phone
FLASHING FROM VERIZON TO CRICKET
This is a great website where i learned a lot about flashing phones from these guys!
If you run into any trouble just shoot me an email and ill be glad to help!
www.mobile-files.com
imprezzadude@yahoo.com
Jan 07, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG VOYAGER VX10000 Cellular Phone Logo
405 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
