Question about Minolta Photography
Film Advance won't work on Minolta X-700
The film advance on my Minolta X-700 will not work.  I replaced the batteries today and there is power (the lights inside showing the shutter speed now light up, and the sound comes on when I try to take a photo with the self timer), but the film advance won't go past about 30 degrees or so.  In the past when this happened, changing the batteries fixed the problem.  Any advice for a cheap, quick fix?
    Scholar:
  • 185 Answers
Changing the batteries have no effect on film transport, just a coincidence. take the bottom cover off and check the white plastic gear on the film take up side of the camera. if it is broken your X700 may not be repairable as no new parts are available.
push the re-wind button in and try to charge the shutter again. remove film first. if it still just goes part way then a gear is stripped. try to find a camera repair shop that may have good used parts available.
Posted on Jul 26, 2009
I recently got a minolta x700, it appeared to be working, the shutter would fire and the film advance lever was working fine even without film or batteries, then when i was going through the functions
What happened when your were testing out batteries and changing the modes? Your question is unclear.
I look forward to hearing a followup question.
Thanks,
BAX
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
atdlee@netzero.com
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
The film advance lever is stuck on my Minolta Hi-Matic C. I bought this at a thrift store today to see if it worked. The film advance lever worked fine for a while and then got stuck. Put a new battery...
Have you rewound the film? If you rewind the file completely and pull out the rewind know, it will pop the back open . . . and can remove the film cassette. While the back is still open, complete the cycle on the winding crank. The winding crank should return to "Normal" arter you complete the winding cycle. When you close the back, everything should go back to normal.
Jul 18, 2017 | Minolta Photography
Film advance stuck and metering problem on Minolta X700
Hi, i have the same problem, do you fix it?, can you give me the solution please?
Thanks, my mail is dg_alex_vargas@hotmail.com
Jan 27, 2010 | Minolta X-700 35mm SLR Camera
Help with minolta x-300s, i cant seem to move the film winder
Well, here's the most likely things going on:
1. dead battery. Your X-300 has an electronic shutter that needs battery power to work. Try fresh batteries and check the battery contact wires for corrosion.
2. End of roll. If you have film in it, try the silver button on the bottom. rewind film and try another roll of film. Before you put in the new film, try the advance, click, advance, click thing.
3. Not all rolls of film are perfect. Some are shorter than they should be, some hang up in the canister.
4. The Minolta X-series were well known to have a problem. Two cheap capacitors on the later models would die, locking up the camera. One is under the top plate and the other under the bottom plate. These caps need to be replaced. I suggest you send it to a repair shop for that. Check prices. Garry's camera repair in Niles, IL does a very economical repair on these. It runs about $50 and $8 for return ship. He will also Clean, Lubricate and adjust it.
You could also buy another 300/370 on Ebay, as they're inexpensive these days.
Best of luck. Hope its just the film or batteries. You might also consider joining the Yahoo Minolta groups.
Jan 19, 2010 | Minolta Photography
Film Advance levar wont work. Milnolta x-700
The Minolta X-series (X-300/370, X-570, X-700) were known for this issue. Two capacitors under the top and bottom covers go bad over time. They prevent the shutter from releasing, so you cannot wind to re-**** the shutter. If you're handy at these things, you can buy the caps, remove the covers, solder in the new caps, and be fine. This issue is well known and you can find instructions on the web. Or you can send it in for repair. Garry's Camera repair in Niles,ILL will do it cheaply at $58 incl return postage. Look him up on the web.
Aug 05, 2009 | Minolta X-370S 35mm SLR Camera
My daughter just got a used Minolta 700-X. We are trying to load the film, but the advance lever won't advance to load the film after we put it in. Can you help?
Are the batteries good ,is the battery cap and contacts clean? Can you fire the shutter? Move select off auto and try to release the shutter. If the shutter fired off auto and will not fire on auto with good batteries. Either the shutter or flex circuit must be replaced. There are no new parts avail. for the X700.
One other item for the X700. check to see if the shutter fully traveled on the last shot.
Dec 07, 2008 | Photography
Film advance lever
No problem.
Most film cameras can do that, for quick advancement.
atdlee@netzero.com
Dec 21, 2007 | Minolta X-700 35mm SLR Camera
Photography Logo
1,210 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
