Question about Canon Office Equipment & Supplies
I have an imageclass D860 it has a new toner but it leave a blank strip on the copies about 2 inches wide. It copies everything else on the page fine.
    Guru:
  • 389 Answers
To define the source of the white band to you it is necessary to do following. During copying in that t moment when paper will be its steal to approach to photo cylinder, switch off kseroks. then дастаньте the block избражения. See, there is on cylinder such blanching band. If on cylinder all well and bands no, search for the problem in corona perenosa.ili in if there is band on cylinder you сследует to call attention what lie the toner on magnetic gross and consequently if he in order, that corona of the charge does the drain. Signifies repeat. 1 have begun the copy, have stopped, look, there is on cylinder correct scene if there is, that one reason corona carrying the scene if no, that several 1. bad lies the toner on magnetic gross 2 hindrances during turning the toner on photo cylinder, 3. does not work blank засветка. Here not it is difficult to understand, and you itself manage, possible обойтисьбез service service. Budte observant and a litle caught, what the process occurs. Thank you, the whole good.
Posted on Sep 12, 2009
The copy quality of canon IR 1600 is very light
Hello, Either the toner cartridge is bad or the fusing unit. Here is manual you can download.
Canon imageCLASS D860 Basic Manual
Jul 03, 2014 | Canon imageCLASS D860 All-In-One Laser...
Canon IR1600 problem light copy
Hello, Either toner cart. for fusing unit is bad. Here is website for manual download.
ImageClass 6530 copies and prints blank pages.
This is either your toner cartridge or more likely the plastic arm that opens the laser shutter is broken. When you insert a toner and close the access door, there is a plastic arm that opens the laser shutter. If this shutter does not open it blocks the laser and results in blank copies. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Good Luck and Thank You for using Fixya.
Mar 19, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Dell 3100cn printer leaves a blank strip
The following table should help
Contamination in the laser path - 1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
Defective fuser - Replace the fuser assembly.
Lack of toner or faulty toner cartridge - Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
Dirty Corona Wire - Clean the Corona Wire.
Defective Drum - Mostly applies to B&W printers. Clean the drum or replace the drum.
Sep 20, 2009 | Dell 3100cn Laser Printer
A copy with a lighter image of the copy on the page
Do printed pages come out better than copies?
If they are the same, you may try another toner cartridge (especially if it is a remanufactured or compatible toner), otherwise, you need your optics cleaned (mirrors and lens under the contact glass)
Mar 06, 2009 | Canon Office Equipment & Supplies
Lines on copies
Went thru Brother tech support on this one. Grab a lint free rag and isopropyl (rubbing) alcohol.
Clean the entire glass on the flatbed. On mine, there is another glass strip to the left of the flatbed about an inch wide, which was the culprit. It had a bunch of gorp on it. Clean! Had to use my fingernail. Then clean the plastic strip where the paper comes out on the underside of the ADF. More glorp, more fingernail. Presto! No more lines.
Aug 01, 2008 | Canon imageCLASS D860 All-In-One Laser...
old marine
old marine
