When operating on battery during a power outage how do I turn off both alarms completely?
SOURCE: setting the alarm on my clock radio
use the selector switch on the top, switch it to wake 1 or wake 2. set the time that you want that alarm to go off. then push the switch all the way back to the left to deactivate it. then to activate the alarm, use the buttons on top labeled wake 1 or wake 2 to turn the desired alarm on. pushing that button repeatedly will cycle the alarm to either beep, radio, or it will turn that alarm off.
SOURCE: CAN U CHANGE THE SNOOZE TIME ON THE ALARM CLOCK AND HOW?
you go to your alarm settings in there you will find the option that snooze time in there you will change the time for snooze
SOURCE: Power outage last night - alarm sounded. Turned
hi..OK 1st step open the unit and find the memory from the board remove the memory then make clean the all pin connectors using a paper eraser.if u have video card remove too then same make a clean..good luck and have a nice day...Thanks
SOURCE: Cannot turn off the alarm on my RCA clock radio rp5430
Look at the display. Look for a number 1 or a number 2 to determine which alarm is on. If you see a number 1, push the 1 button on the top right side of the alarm clock until the number light goes off (1 or 2 times, depending on whether it is set to beep or radio alarm). When the number is not lit up, the alarm is off.
SOURCE: Cant turn off alarm on RCA alarm clock model 3715A
Closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
It is almost exactly the same model as the #3700 series.
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
