Question about Canon BubleJet i965 InkJet Printer
Canon i455 printer displays canon service error 5C00
When I turn my printer on there is a high pitched "ratchetty" sound. The printhead does not appear to move and I cannot retrieve it manually from the far right position as I face it. The indicator light on the top of the printer flashes green and then amber continuously. When attempting to print using Microsoft Picture It! Photo 7.0, I receive a Canon service error 5C00.
    Problem Solver:
  • 8 Answers
Paper mechanism is vey suspect - time for a new one
Posted on Jul 21, 2009
CANON MG8100 series error 5C00
Per http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5c00
5C00 - Orange and green blinking 4 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
May 27, 2014 | Canon PIXMA iP3500 Printer
Canon pixma MarkII pro 9000 has an error 5C00 or purge error?
That is probably some paper or a foreign object inside the machine. Check around the waste station and at the far end of the printhead travel in both directions. Remove any found foreign objects and restart the printer. If there is nothing there to find - it is probable that the is a mis-alignment of the gear train that selects the various functions of cleaning, paper feed, and waste purging. In that case, there is not a lot you can do short of a complete strip down and rebuild with no guarantee of succes.
Jan 30, 2014 | Canon Pixma Pro 9000 MARK II InkJet Photo...
I am getting an error message for my Pixma iP90 Printer and it is 5C00 can you help
5C00 is a purge unit error, the purge is the unit that cleans the printhead on the right hand side. If the printhead will come out of the right side, you will need to check for paper scraps caught in there, If stuck on the right you will need a shop to check it out for you so you don't break anything. You need to remove covers and printhead and check under the printhead in the purge unit.
Feb 22, 2010 | Canon PIXMA iP90 InkJet Printer
Canon iP90 error 5C00
5C00 is a purge unit error, thats the cleaning unit on the right where the printhead parks. Look inside with a flashlight, if nothing is blocking it's operation, you willl need a new print engine, qm2-2020-000 around $150.00
Jul 21, 2009 | Canon PIXMA iP90 InkJet Printer
Error code 5C00
Error code 5C00 refers to a purge unit error. This is a service call error and requires that the printer be taken into a canon authorized service facility for diagnostic and proper repair.
May 15, 2009 | Canon I900D InkJet Photo Printer
Canon printer ix4000 service error 5C00
bagai mana caranya menanggulangi eror 5c00 Printer ix4000, mohon petunjuknya
Apr 01, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Canon ip3000 shows service error 5c00
5C00 is Purge unit error.Check for object around the purge unit.
Feb 23, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Service error 5C00? what's that?
Service error 5C00 is a purge unit error. The purge unit like a spitoon to the printhead where is stops. There is a sensor in the purge unit; when it is blocked (usually by ink build up), that error is given. The error indicates that the purge unit may be full or at least gunked up. It may be possible to clean the purge unit and sensor to make the error go away. I base this on information learned with experience on another Canon product (Model i560). Hope this helps...
May 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Service error 5C00
Service error 5C00 might indicate the purge system.
The "rattling sound " is probably coming from the (gears of-) socalled purge unit. May be one ( or both) of the ink tanks is not properly put back in again,or the printhead-lock is not locked. and the purge system is blocked.
Remove the ink tanks and remove the printhead, closw the printhead-lock, close the printhead cover, switch the printer of, switch the printer on again. If the rattling sound is still there, than you might have an expensive problem to be solved.
If the rattling sound is gone, there is probably something wrong with the printheadlock.
Mar 12, 2008 | Canon i80 InkJet Printer
Canon BubleJet i965 InkJet Printer Logo
254 people viewed this question
old marine
old marine
