Question about Dell PowerEdge R905 Server
I have a slider window I need to remove to bring in a pool table,can't find any screws to remove ,found only a tag with this info AAMA SPONSERED S/N720 315004
    President:
  • 1,335 Answers
There are tension wheels on the top and bottom (2 at each end) of the slider window. You have to lift the slider window and lift the bottom wheels off the track to be able to remove the window. The reverse to reinstall.
Posted on Jul 18, 2009
Want to unlock sansui turntable p-l51
I don't know what you mean by locked, but if the table won't move and is locked in place, you probably still have the shipping screws in place. Remove the rubber mat and the platter. Under there, you will generally find red screws or screws with tags that must be removed to allow to platter to turn. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 04, 2013 | Audio Players & Recorders
Tip
Computer Audio
There are quite a few people out there having problems with installing a new version of windows and or re-installation of windows and loosing there audio driver for the sound. This can be easily fixed.
You will need to go to the manufactures website. EX: www.dell.com,www.hp.com ECT....
Than you will need to click on support.
Once there you will need to enter your model number and or serial number than search. ( DELL customers will need to use the service tag number, This can be found on an oblong sticker on the side or back of the computer. Some models have the flip cover on the fronts there will be a service tag under the covers.)
This should bring up the window for your PC(Personal Computer) Once there look for the tab or link for software and driver downloads. click on that link.
Once this is done you will need to look for a driver for the Sound and or Audio. Once this is found you will need to download the driver and click SAVE than run it on your computer. You will need to restart your computer and your sound should work.
If you are needing any further assistance please do not hesitate to ask.
I will need the following information to help you. Make,Model and serial number of your (Personal Computer) PC as well as the operating system. EX: Windows Home 64, Windows Home, Windows Professional ECT...
NOTE:For DELL customers please provide me with the service tag number as well. This can be found on a oblong sticker on the side or back of the computer. Some that have the flip covers on the front the service tag can be found under the plate.
on Jan 23, 2010 | Computers & Internet
I want to buy a pool table for my basement, but I don't know if the room is big enough. How big of a room do I need for a billiard table?
It obviously depends of what size table you are buying. I found you a great chart that outlines the various table sizes and the dimensions the room should be for each.
Jul 25, 2012 | Sport & Outdoor - Others
Do they make lounge chairs for the pool like massage tables, so that you can lie on your stomach?
That is a great idea! Inever thought of that. I was able tofind you a link to a company that actually makes such a chair. Here it is:http://www.amazon.com/dp/B00075LUKM/?tag=047-20
May 29, 2012 | Furniture
How do I change brushes on my Nutool hs2500 table saw
You got to strip the machine down. Switch off, bring saw blade down to below table level, turn over machine remove 4 Phillips screws undo and remove guard remove motor, strip down motor replace parts and generally wipe clean, ensure brushes allow armature to turn freely. Refit in reverse order. bingo.
Aug 19, 2011 | Garden
How to disassemble impeller on rs1000 hayward pump
OFF TO THE LEFT FOR REMOVAL OF A IMPELLER BUT SOME MAY HAVE A SCREW IN THE CENTER IT IS A LEFT HAND THREAD SO IT OFF TO THE RIGHT.. BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY TO HAVE IT DONE RIGHT
Jun 29, 2010 | Hayward 1.5 Hp Northstar High Performance...
Remove door panel
Remove the screws and lift up. There aren't any screws behind the window switch, it is screwed on from behind. There is a hidden screw behind the lock slider.
Mar 01, 2009 | 2000 Chevrolet Silverado
Windows not loading
I believe the boot key sequence is - CONTROL F11, should bring up a "boot from..." screen. from there you should be able to start a system restore. Personally it sounds as though your boot table got messed up.
Dell does have system restore disks available. Need model number, tag number, etc ... http://support.dell.com should be the right link to get that started. might take a couple weeks, each setup series of disks are specific to the make/model of the machine (so, generally non transferrable unless you know exactly what you are doing)
If you need more help, contact me through this site.
Rob junod
Jan 12, 2009 | Dell Dimension 2400 PC Desktop
Passenger side window
disconnect the battery. remove the door lock knob. remove the bezel around the interior door latch by sliding the bezel towards the front of the car. carefully pry off the air bag logo. There is a torx screw under it - remove said screw. Carefully pry off the two screw covers under the door pull - there are two torx screws under these two covers - remove the screws. With a flexible flat spackling tool, caerfuly run the tool around the door cover, releasing the clips that hold the cover to the door. lift the door cover away from the door, and disconnect the front speakers. disconnect and remove the airbag. Carefully remove the foam liner, exposing the window mechanism.  Carefully pry up and remove the drip rail from the interior side of the window. re-install the air bag (else you'll set an error code) and reconnect the battery. Run the window up or down as needed to expose the connection between the window and the lifter mechanism. disconnect the clips on the two sliders that run in the channel on the metal clip attached to the bottom of the window and carefully press that slider towards the door - which will unclip the slider from the lifter mechanism. Now the window should pull up and out of the car.
replacing the window is the reverse of all this, making sure the window is aligned in the tracks inside the door so that it goes up and down smoothly.
All I need now is to figure out how to adhere that track to the bottom of the window - that's what broke on my car - something that will adhere to the glass and metal!
Jan 09, 2009 | 1999 BMW 328 Series
Can any one figure out code for this pseudocode?????
its the psuedo code for a function in some sort of word processing application. basically it looks for a word, noun , phrase or period. and record the position then adds it to a table.. Proberally home work for a programmer i guess.
Feb 20, 2008 | Computers & Internet
Dell PowerEdge R905 Server   Logo
54 people viewed this question
Alun Cox
