Question about Samsung Q1 Ultra Mobile PC CMPX Intel A100 80GB HD, 1GB RAM, 7-inch Widescreen Display, Dual Camera,... Led Printer
Where is the real time battery?
I need to change the "real time battery" or backup battery on my Samsung Q1 but don't know where it is.
How do install a backup battery in my hp iPAQ hx 2750?
try HP ?
ask them?
you need manual. most things this old the manuals are hard to find
so ask HP or learn to google?
the real HP forum and support !
https://h30434.www3.hp.com/
Jun 29, 2017 | HP iPAQ HX2750 Pocket PC
If my battery for my computer is shot will my little backup battery need to be replaced as well
The BIOS battery may not need changing provided the Date and Time setting does not change each time you boot up. If the laptop is more than 3 years old then it you can elect to replace the BIOS battery.
Feb 16, 2012 | Computers & Internet
How to fix not working touchscreen? Do i have to replace it?
The Samsung Q1 is a hybrid, ultra-mobile, touch-screen device that is basically a very small tablet PC. It features a 7-inch screen, weighs a mere 1.7 lbs., features a Windows operating system, doesn't have a built-in keyboard, and comes in a variety of configurations. The Samsung Q1 doesn't offer outstanding battery life, but you can make some moves to boost your computing time.
Dim the Screen
Dim the screen brightness. Four programmable application-launch buttons occupy the right edge of the Q1. One of these, the menu button, calls up frequently-used controls, including screen brightness. Reduce the screen brightness as much as you can, as it's one of the best ways to extend battery life.
Close Power-hogging Apps
Close applications and browser windows when you're done with them. Too many open programs drain the battery. Beware power-hogging apps. Watching a video or listening to music on your Q1 drains your battery life much faster than just using Microsoft Word or checking email. Turn off the Wi-fi networking when not in use. The built-in Wi-fi searches for a network when you're not connected, which drains battery life.
Properly Caring for and Feeding a Battery
Unplug the Samsung Q1 after the battery is fully charged. Leaving your Q1 plugged in 24/7 leads to some discharge from the battery. Consider buying a bigger battery. A 3-cell battery comes with most configurations of the Q1, but you can also buy a 6-cell battery to double the battery life.
Room Temperature is Best
Don't expose the Q1 to harsh conditions. Keeping the device in a blazing hot car in direct sunlight harms your battery life. If you use your Q1 in conditions above 95 degrees Fahrenheit, you can permanently damage the battery. Cold conditions don't harm the battery in the same way, but if you leave the Q1 in the cold, let it warm to room temperature before you use it.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | Samsung Q1 Tablet PC
I cannot adjust the brightness of my samsung N150 plus mini laptop
me too, same problem...going into the bios and changing to user controlled makes no difference, also changing the power settings makes no difference - even if unplugged.
anyone know?? much appreciated
Dec 20, 2010 | Samsung Q1 Ultra Tablet PC
Samsung q1 bios password reset - how?
why cant i change my bios password for my samsung np-q1
Feb 01, 2010 | Samsung Q1 Ultra Tablet PC
I can't update my firmware on my yp-q1. it says
Don`t try to use Emodio.  It will just not do it.  Go on the Samsung site, under support type in your model and download the latest firmware.  Also download the upgrade guide (PDF).  It is very simple.  I did it and got my Q1 upgraded to 1.34 US.  ( as they say you will have to restart it twic.
Have fun.
Michel
Mar 22, 2009 | Samsung Yepp YP-P2 Digital Media Player
Samsung Q1 wireless netowkr switch?
There is no wireless switch for the Q1. Go to "network connections", "right click" your "wireless network connection" and then click "enable".
Feb 18, 2009 | Samsung Q1 Tablet PC
Q1 ultra not booting
Fixed it. Opened the back cover and reinserted the memory.and it bootedup. So I guess memory got loose.
Feb 17, 2009 | Samsung Q1 Ultra Tablet PC
I dropped my q1 and the battery fell out. I tryed to restart, but now I just get a gray screen. PLEASE HELP!!!!
Assuming that your battery is making proper contact with the Q1 battery terminals, this problem suggests that your hard disk drive has been disturbed from the shock the system received when it was dropped. You may have lost all the data in your Q1. You may have to reinstall the system.
Jan 14, 2009 | Samsung Q1 Tablet PC
Samsung YPQ1
I had the exact same problem with my Windows XP when trying to interface with my new Samsung YP-Q1 16GB. Hey, it took a bit of Forum searching but it can be done.
Load your Emodio software from the supplied CD.
Download Windows Media Player 10 or above (important)
Plug in your MP3 Player to USB port (hopefully your USB ports are USB2.0 otherwise you'll need to see if you can upgrade their drivers to make them USB2)
If, as with mine, its still not appearing as a portable device in Windows Media Player or EMODIO
then
Go to Control Panel. (I prefer Classic view where you can immediately see Add Hardware Wizard)
Run Add Hardware Wizard. searches for new Hardware. Prompts for is Hardware connected?)
Look at list of devices Q1 should appear as yellow Q1?
Highlight Q1 and continue.
Prompted for dowload of MTP file.
Install file.
Hey presto....
Worked for me anyway although Emodio software still had problems writing to Q1, Windows Media Player had no such problem.
Dec 30, 2008 | Audio Players & Recorders
Samsung Q1 Ultra Mobile PC CMPX Intel A100 80GB HD, 1GB RAM, 7-inch Widescreen Display, Dual Camera,... Led Printer Logo
53 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
