Cars & Trucks Logo
Posted on Jul 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 dodge neon codes p0731, p0700, p0573 and p0720
I have a 2005 dodge neon sxt 2.0engine and just recently start having problems now i just recently changed the transmission shift solenoid in the car and im thinin i had changed the wrong part now the codes i recieved from autozone diagnostic test are p0731,p0700,p0573,and p0720the speedometer shows dat when im going 40 it stays on like 0 and as far as the rpm's go it jummps from 1to 3 without me nowing and also it jers and is hard to pick up speed check engine light has been on for 2 weeks now and the car has not been driven since please help me with this issue concerning the neon what parts do i need to purchase
Anonymous
Level 3:
  • Master 335 Answers
  • Posted on Jul 18, 2009
Anonymous
Master
Level 3:
Answers
335
Questions
0
Helped
176789
Points
1203
The codes listed all point to the transmission being in bad shape or some wiring got crossed. Check with a trans shop for an estimate.
2helpful
2answers
I have a 2004 dakota codes p0052 p0732 p0720 p0731 p0700. Bought non running and had a 3.7 installed got back and it jerks when taking off and won't shift out of 1st gear. Limp mode? Any ideas?
P0700 Transmission control system malfunction
P0720 output speed sensor circuit malfunction
P0731 gear ratio error in first gear
P0732 gear ratio error in second gear
2005 Chrysler Sebring with error codes p0700,p0720,p0731
2006 Sebring Convertible - Transmission Codes - P0700, P0720, & P0731....
2006 Sebring Convertible, started while driving around town - transmission did not want to shift and CEL came on. Stopped, checked transmission fluid and looked for anything obvious. All fluids good, nothing obvious. About 5 miles from home, drove back roughly 15-20 mph. Only other issue that had came to mind was the alternator had been making a whining noise for some time, probably 3 months or so - had mentioned to wife that we should replace it before it completely failed. Found one reference on the internet that the alternator could cause weird electrical conditions / interference if bad - leaking voltage back through ground. Thinking the alternator likely needed replacing anyway, I replaced it and cleared codes - all issues were solved - no more alternator whining and all transmission issues resolved. Replaced alternator on Sept 9, 2019 today is Sept 12, 2021 and still going - I think its safe to say the alternator was the culprit in this instance.
How many sensors o2 dodge neon have
P0732 Gear 2 Incorrect Ratio
P0720 Output Speed Sensor CKT Malfunction
P0736 Reverse Incorrect Ratio
P0500 Vehicle Speed Sensor Malfunction
P0700 Trans Crt l System Malfunction
P0731 Gear I Incorrect Ratio
I have a 2004 dodge neon sxt and the codes im getting are, p0175, p0700 and p0731
1-P0175 is running rich. This will need to be checked by a mechanic unless you have some very expansive and highly technical machines too.
P0700 and p0731 both have to do with transmission malfunctions. Please - these things are not for at home unless you have the electronics2_bing.gif and know your way around the cars.
YOU CAN DO THIS - take down the VIN number and call the dealer - ask if any RECALLS are on your car2_bing.gif. This has saved many people thousands of dollars and you do not have to have bought the car new or even own it now to get these fixed.
TRY THIS -
1- Take the negative battery cable loose
2- Take the gas cap off and replace it [ really works
3- you might want to replace the air filter if you do not remember when the last time it was done.
4 - reattach the battery and drive the car for 20 minutes or so to see how that goes.
If this fails please take it to a dealer or a very reputable mechanic with the proper tools as you can end up making it worse because of the computers today.
1helpful
3answers
Is it the 2.0? I have some codes for the 2.0. I had one! Fun to drive but always in the shop. Here is what i found...
p0175 - System too rich (bank 2)
p0700 - Transmission control system mil request
p0731 - First gear incorrect ratio
I hope this stuff helps!
2helpful
I have a 2005 Dodge Neon and the engine light came on. It has codes P0700 (Transmission Control System (MIL Request); P0720 Output Shaft Speed Sensor Circuit; P0731 Gear 1 Incorrect Ratio
a had the same problem. i am 99.9 percent sure that the wires going to the sensors underneathe the battery box and air intake are broke inside the insulation. Get to where you can see the connectors. remove the tape from both sensor connectors and give the wires a pull each wire done seperately. Mine was an orange wire and a purple wire. It is not noticeable by looking at the wires because it is the copper wire inside the insulation that will be broke. Find the broke ones and splice in new wire and the problem will be fixed.
3helpful
2answers
2005 Dodge Grand Caravan SXT Malfunction
I have Dodge caravan 2010 and my falfunction light is on,what do i do?
2005 Dodge Neon SXT P0700 error code
check to see if your tentioner spring loaded pulley is operating properly.
i.e. you can move it with hand pressure it can be to hard to move or too easy.
both can cause this problem. loosen or tighten the retainer bolt.
6helpful
2005 PT Cruiser P0700, P0720, P0731 stuck in low and Speedometer
YOU HAVE A DEFECTIVE OUTPUT SPEED SENSOR ON TRANSMISSION..ABOUT 40 BUCKS,DEALER PART..SCREWS INTO FRONT OF TRANS..NEAR LEFT INNER FENDER,YOU MIGHT WANT A MECHANIC TO REPLACE..
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
